Hi,
Just got around to adding my ORP probe and noticed as soon as I put it in the sump, my salinity jumps up about 2 points.
This is immediate and if I remove the ORP probe, the salinity immediately goes down etc.
So there is def some interference from the ORP probe on the salinity.
I also tried placing the probe about a foot away from the salinity probe and exactly the same effect.
Surely this shouldnt happen?
ORP Probe interferes with Salinity Probe?
Re: ORP Probe interferes with Salinity Probe?
Correct, this shouldn't happen.
May I ask to use a cup of tank water or any other container and do the same exercise in it?
Does it also interfere the same?
Hi Roberto,
Just done this an yes, in a cup it jumps about 2 points also as soon as the ORP electrode is added.
You will need to send them for repair then.
PM for RMA
PM for RMA
Just for anyone who may have a similar thing, Roberto helped me isolate this, and it was my induced problem as I used the same power supply to power the salinity and ORP module causing the problem.
When using separate supplies, it works fine!!
