I've never done it before so its probably a simple solution but I am having a problem with port forwarding. I tried using simpleportforwarding but I cant get it to work. My ip website and android app work fine when I am in my house but I cannot access it from anywhere else. I have a cisco DPC3825 router. Theres a bunch of ips and I don't know what to do with them. theres a computer ip, hostname ip, router ip, and current local ip... as you can probably guess I'm not very computer savy. any help is very much appreciated.
here is what happens when I try to port forward using simpleportforwarding:
Router: Cisco - DPC3825 (Cisco Firmware)
Loading Commands...
Number Of Port Forwards To Send To Router (1)
Running Commands...
(Current - 1/1)
Adding reef angel (TCP) For Ports 2000-2000 To 192.168.0.12()
Running Script From Database For Selected Router
Step 01. nav_first_only("")
(Successful) (http://192.168.0.1/)
Step 02. set_username("username_login")
(Successful)
Step 03. set_password("password_login")
(Successful)
Step 04. click_button_first_only("login")
(Successful)
Step 05. nav_first_only("AppGaming.asp")
(Successful) (http://192.168.0.1/AppGaming.asp)
Step 06. timeout("1000")
(Successful)
Step 07. check_if_name_exists("")
Step 08. set_name_array("1|2|3|4|5|6|7|8|9|10")
(Successful)
Step 09. set_name_to_check("PortForwardPortGlobalStart,0")
(Successful) (Current Name From Name Array PortForwardPortGlobalStart1)
Step 10. set_start_port("PortForwardPortGlobalStart,0")
(Failed - Object Not Found)
Step 11. set_stop_port("PortForwardPortGlobalEnd,0")
Step 12. set_type_choices("TCP|UDP|BOTH")
Step 13. set_combobox("PortForwardProtocol,0")
Step 14. set_ip("PortForwardAddressLocalIPX,3")
Step 15. set_checkbox("PortForwardEnable,0")
Step 16. click_button_last_only("Save Settings")
Finished Adding reef angel
-------------------DONE! (All Commands Finished)--------
PORT FORWARDING
Re: PORT FORWARDING
Are you sure the wifi attachment is using 192.168.0.12?
If you look in the attached devices list, it will be listed as ReefAngelWifi
