Ph probe keeps resetting to 1.00 a few hours after calibrati
ecam
Post by ecam »
When the probe is calibrated. Are the setting stored anywhere that I can restore? It appears my calibration got wiped out when I was uploading some code. It seems like this happened after I plugged in my third temp probe. Any ideas?
Re: Ph probe keeps resetting to 1.00 a few hours after calib
You can add this to your code, inside the setup() section:
 ReefAngel.PHMin=830; // PH10.0
 ReefAngel.PHMin=540; // PH7.0
ecam
Post by ecam »
Still not working... Here is what i did
ReefAngel.Init(); // Initialize Controller
ReefAngel.AddStandardMenu();
ReefAngel.AddDateTimeMenu();
ReefAngel.FeedingModePorts = Port5Bit | Port6Bit; // Turn off Ports 5 and 6 when Feeding Mode is activated
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit; // Turn off Ports 1, 5, 6, 7 and 8 when Water Change Mode is activated
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port7Bit; // Turn off Ports 3, 4 and 7 when overheat occurs
ReefAngel.LightsOnPorts = Port3Bit | Port4Bit; // Turn on/off Ports 3 and 4 when Light On/Off menu option is selected
ReefAngel.Relay.On(Port8); // Always on
ReefAngel.PHMin=544; // PH7.0
ReefAngel.LCD.DrawLargeText(COLOR_STEELBLUE,COLOR_WHITE,28,121,"Reef Angel"); // Display Reef Angel banner
ReefAngel.StandardATO(Port1); // Standard ATO
ReefAngel.MoonLights(Port2); // Moonlights or Refugium
ReefAngel.StandardLights(Port3,30); // Actinic Lights
ReefAngel.StandardLights(Port4,0); // Daylight Lights
ReefAngel.Wavemaker1(Port5); // Wavemaker 1
ReefAngel.Wavemaker2(Port6); // Wavemaker 2
ReefAngel.StandardHeater(Port7); // Heater
ReefAngel.PWM.StandardDaylight(); // Dimming for Daylight Channel
ReefAngel.PWM.StandardActinic(30); // Dimming for Actinic Channel
ReefAngel.ShowInterface(); // Display everything on the LCD screenfa
One has to be PHMin and the other PHMax
ecam
Post by ecam »
did that and still not reading right... reading 1.50 fpr ph
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <ReefAngel.h>
    ReefAngel.PHMax=830; // PH10.0
Which numbers did you get when you were doing the calibration?
ecam
Post by ecam »
i used the numbers from the calibration which were slightly off from yours... so you sent 540 and 830,
i used 544 and 830 from my calibration. I used both sets of number to no success.
Can you go through the calibration again and confirm you are indeed getting those numbers?
ecam
Post by ecam »
Just did it again and confirmed the numbers. as 544 abd 830. It worked for about an hr and then went back to 1.49 for ph
If you enter calibration while it is showing 1.49ph, what number do you get?
ecam
Post by ecam »
As of right now. It's registering correctly. I will let you know if its starts acting up again. Thank you
