surging or rapid on/off of kalk reactor
sulcata102
Post by sulcata102 »
My tunze osmoregulator, which is connected to a kalk reactor is set to come on at 8.10 and off at 8.20. It is connected to port two of my relay box. I used the reef wizard to set it up. The problem is that when the controller reads 8.1 the tunze flips on but then one second later it when the ph read 8.11 it flips off. this will continue unless the ph can be driven lower either by the calcium reactor and/or at night. I tried to go into reef wizard and change some of the ph settings, either raise or lower it, but now every time i get to the end of the reef wizard it says there is an error and will not let me proceed. It doesn't even say what the error is. the real stick in the eye is that nothing has changed since it was set up. After all the trouble i had just getting to the point the reef wizard finally worked, or so i thought, i decided to leave my old laptop in the same spot, program wise, and not change anything. well two days later when i realized the tank is not filling and the tunze is blinking on/off i go to update and I get that error message.
Re: surging or rapid on/off of kalk reactor
Can we see your code?
sulcata102
sure. how?
sulcata102
ReefAngel.WaterChangePorts = Port8Bit;
ReefAngel.CO2Control( Port1,795,785 );
ReefAngel.PHControl( Port2,820,810 );
ReefAngel.StandardLights( Port3,8,0,21,0 );
ReefAngel.StandardLights( Port4,9,0,19,0 );
ReefAngel.Relay.DelayedOn( Port5,240 );
ReefAngel.DosingPumpRepeat( Port6,0,60,120 );
ReefAngel.StandardHeater( Port7,785,796 );
ReefAngel.Relay.DelayedOn( Port8,10 );
sulcata102
it will not let me copy paste the error code though. any ideas?
sulcata102
it says that it automatically added: watchdog timer and version menu.
also seems like....
c:/Documents and settings/terri dedrick/my documents/arduino/libraries/ds1307rtc/ds1307rtc.cpp:94:error: 'class Twowire' has no member name 'write'
c:/Documents and settings/terri dedrick/my documents/arduino/libraries/ds1307rtc/ds1307rtc.cpp:94:error: 'class Twowire' has no member name 'read'
those two messages like 40 times
It looks like you got old libraries somehow.....
Please uninstall the Reef Angel Installer.
Then, rename or delete the folder "Documents\Arduino"
Install the Reef Angel Installer again.
That should bring back the libraries to most updated version.
For your pH problem, try this:
ReefAngel.PHControl( Port2,810,820 );
sulcata102
ok, i'll try it, thanks.
sulcata102
my computer locked up the other day before i got a chance to do as you suggested. I just got it working good again. So i uninstalled the reef angel and reinstalled it. it is giving me the same error code again. do you know any way i an copy/paste the error message? i would like to post it, so you can see.
You can copy the error by selecting the error in red and then using the keyboard shortcut CTRL+C
sulcata102
Using Port : \\.\COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: Send: 0 [30] [20]
avrdude: Recv:
avrdude: stk500_getsync(): not in sync: resp=0x64
avrdude done. Thank you.
Please check if you have the correct board under menu Tools->Board and also the correct serial port under menu Tools->Serial Port
sulcata102
I tried both com ports and i tried both the reef angel board and the reef angel with optiboot(not sure what that is) no options worked. I know I don't have the plus so i didn't bother with that one. still get error code:
Using Port : \\.\COM3
avrdude: Recv: 0 [30]
avrdude: stk500_getsync(): not in sync: resp=0x30
Did anything change from the last time you were able to upload your code?
