upload to internal memory
how do I do it?
and how do I know where everything is so I can change it on the fly from the android app.
Adam
58 Gal
![Image](http://forum.reefangel.com/status/banner_4.aspx?id=Ademster&t=-7)
58 Gal
Re: upload to internal memory
You need to generate a code with the Wizard and choose internal memory.
Then you can use android to change the values.
last time I tried it did pre-set values for the lights, I run them opposite of my dt lights and it wont let me do it custom it presets them.
how can I upload directly into the head unit with out using the wizard?
Adam
58 Gal
58 Gal
- DrewPalmer04
Not sure...BUT if you know the internal memory locations you could just use the serial monitor and the GET/ command?
So, GET/mb(memory location),(value you want)(space) enter.
GET/mb855,3(space) ENTER would set my internal memory location for RF expansion to tell my mp10 to use short pulse. ETC
If you already uploaded a code that uses internal memory, just use the Android app to change the values.
I only wanted the pwm to be internal and a few other things.
I figured it out. if you leave the values blank, you can control it with internal memories.
Adam
58 Gal
58 Gal
how do I know what the start time and end time is for the pwm lighting?
I want it to be on at 11 and off at 9
Adam
58 Gal
58 Gal
I figured out how to do it, back then. Now that I had to add the orp module, pwm module, relay expansion module. I don't remember what I did to have it in the internal memory.
using the wizzard didn't help...
anyone show me their code for pwm parabola code that is in their internal memory
Adam
58 Gal
58 Gal
Try this:
