Actinic light cycle
kahlif
Actinic light cycle
I have a basic, non-dimmable actinic light. I want it to come on at different times of the day.
So, lets say on port 2, I want it to be on:
from 8-9:30 am (sunrise),
15 min intervals at 8 different times between 10am and 6pm,
from 6:30-8 pm (sunset).
Any example?
Any example?
Re: Actinic light cycle
// Sunrise
ReefAngel.StandardLights(Port2,8,0,9,30);
//Sunset
ReefAngel.StandardLights(Port2,18,30,20,0);
// 15min interval
ReefAngel.StandardLights(Port2,10,15,10,30);
// Do the same another 7 times
kahlif
So, dredging up my old question, since I finally got my RA up and working...
This little bit isn't working. My actinic stays on all day.
So, code is:
Seems pretty straightforward, what am I missing? I have no other reference to the port through my code.
So, code is:
// Sunrise
ReefAngel.StandardLights(Box1_Port2,8,0,9,30);
//Sunset
ReefAngel.StandardLights(Box1_Port2,18,30,20,0);
// 15min interval
ReefAngel.StandardLights(Box1_Port2,10,15,10,30);
ReefAngel.StandardLights(Box1_Port2,11,30,11,45);
ReefAngel.StandardLights(Box1_Port2,13,0,13,15);
ReefAngel.StandardLights(Box1_Port2,14,15,14,30);
ReefAngel.StandardLights(Box1_Port2,15,0,15,15);
ReefAngel.StandardLights(Box1_Port2,16,15,16,30);
ReefAngel.StandardLights(Box1_Port2,17,15,17,30);
Actually...
Sorry... This code would never work....
I don't know what I was thinking when I posted....
Only on StandardLights function would work... The last one would always have priority.
if (hour()<10)
// Sunrise
else if (hour()>=18)
//Sunset
else if (hour()==10)
// 15min interval
else if (hour()==11)
// 15min interval
else if (hour()==13)
// 15min interval
else if (hour()==14)
// 15min interval
else if (hour()==15)
// 15min interval
else if (hour()==16)
// 15min interval
else if (hour()==17)
// 15min interval
kahlif
So, it seems I am still having the same issue. The actinic stay on all day and night...
kahlif
An actinic stunner strip
kahlif
That did it!
Port 2 then has a busted relay? I moved it to port 8 and changed the code, and it is cycling on and off like a charm.
So, I have a port that doesn't cycle and the relay expansion module with the loose USB port...
Can you load the ControllerTester and test each of your relay boxes?
