Nokia N82 TFT for Arduino Mega
Re: Nokia N82 TFT for Arduino Mega
Nice.
I have a slightly larger screen in the works.
It's a 2.8" screen.
http://forum.reefangel.com/viewtopic.ph ... =prototype
Anyone interested in designing the new user interface???
I got a prototype enclosure too.
I'll post pictures later.
It's a 2.8" screen.
- jsclownfish
Is you're prototype a touchscreen? or does the new enclosure have a joystick? I use my "auxillary" monitor http://forum.reefangel.com/viewtopic.php?f=11&t=923 fairly often to see what's going on in the tank and timing, but it really helps to be able to toggle through screens of info with the joystick.
-Jon
-Jon
It actually has touch screen, accelerometer for tilt adjustment and SD card reader
The accelerometer will auto adjust the screen to whatever angle you place it, just like on your smart phone
- DrewPalmer04
I'd love to see this pushed ahead in the dev. People would buy a screen upgrade in a heart beat....or I would at least. The screen now is good for looking at specs at a glance but the options for larger/better screen would set RA apart from other controllers.
http://i761.photobucket.com/albums/xx25 ... 172302.jpg
I still need to design an overlay for it and recode the libraries.
The supplier stopped manufacturing the screen with the driver I was testing and has gone with a new driver, so I'll need to revise the libraries and make sure that everything is working the same. I placed an order for new sample screens to create a new prototype and should be here in 3 weeks. So, this product has been moving, just very slow
This one is also in the works:
http://i761.photobucket.com/albums/xx25 ... 103933.jpg
Reef Angel Mini
It's a remote screen too that uses the same screen of your head unit, but doesn't have the accelerometer, touch screen or SD card.
It has a very simple up/down and select joystick on the side.
I just finish this prototype and need to do further testing now
Reef Angel Mini
- jsclownfish
Wow, that looks just like what I envisioned when I was working on the auxiliary monitor before I went with using the original RA. I like the streamlined prototype a lot.
Jon
Jon
I like what im seeing so far Roberto!!
Nice link here to the N82 on Hackaday. Might give you some ideas on implementing it with the RA.
http://andybrown.me.uk/wk/2012/08/19/nokia-n82-arduino/
-=Bryan=-
It doesn't have touch capability and it runs on 8bit
I'm using one with touch and 16bit.
I decided to pick up this again.
I'm designing a new prototype board that should be ready in a few weeks.
In the mean time, I'm working on the libraries.
