voidsetup()
{ // This must be the first line ReefAngel.Init(); //Initialize controller // Ports toggled in Feeding Mode ReefAngel.FeedingModePorts = Port1Bit; // Ports toggled in Water Change Mode ReefAngel.WaterChangePorts = Port1Bit | Port4Bit | Port6Bit; // Ports toggled when Lights On / Off menu entry selected ReefAngel.LightsOnPorts = Port2Bit | Port3Bit; // Ports turned off when Overheat temperature exceeded ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit; // Use T1 probe as temperature and overheat functions ReefAngel.TempProbe = T1_PROBE; ReefAngel.OverheatProbe = T1_PROBE;
// Ports that are always on ReefAngel.Relay.On( Port1 );
voidloop()
{ ReefAngel.DayLights( Port2 ); ReefAngel.ActinicLights( Port3 ); ReefAngel.StandardHeater( Port4 ); ReefAngel.StandardFan( Port5 ); ReefAngel.SingleATOHigh( Port6 ); ////// Place your custom code below here if (ReefAngel.LowATO.IsActive()) ReefAngel.Relay.Off(Port6); if (ReefAngel.HighATO.IsActive()) if (ReefAngel.LowATO.IsActive()) ReefAngel.Relay.Off(Port1);
// This should always be the last line ReefAngel.Portal( "emict326" ); ReefAngel.ShowInterface();
there is my code generated by the reef angle wizard, every time i try to upload it i get an errror ocured need help
Oh, you are getting compile errors...
Uninstall the RA installer and delete the folder "Documents\Arduino"
Then download and install the new installer.
