Salinity Temp Compensate's Reading
Dugong
Post by Dugong »
So, according to this post http://forum.reefangel.com/viewtopic.php?p=7386#p7386, it could be done using the following code:
  double SalCompensation;
  if (TempSensor.unit)
    SalCompensation=Params.Salinity/(1+((Params.Temp[T1_PROBE]-250)*0.0024));
    SalCompensation=Params.Salinity/(1+((Params.Temp[T1_PROBE]-770)*0.001333));
  Params.Salinity=round(SalCompensation);
And I'm planning to calibrate the salinity probe using the solution with 25C temperature. The question is, where do I put above code? Is it in the setup() function? Thanks.
Re: Salinity Temp Compensate's Reading
Do you plan on calibrating at 25C and monitoring at various different temperature ranges?
Dugong
Post by Dugong »
rimai wrote:Do you plan on calibrating at 25C and monitoring at various different temperature ranges?
Yep.. that is it.
Please post your code.
Dugong
Post by Dugong »
here they are:
    ReefAngel.FeedingModePorts = Port4Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port8Bit;
    InternalMemory.OverheatTemp_write( 350 );
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.Relay.On( Port7 );
    //blue light, on 5:20 PM, off 1 AM,  7 hours 40 minutes
    //ReefAngel.StandardLights( Port1,17,20,1,0 );
    //blue light on 3:00 PM, off 10:00 PM, 7 hours
    ReefAngel.StandardLights( Port1,15,0,22,0 );
    //white light, on 6:20 PM, off 00:01 AM, 5 hours 40 minutes
    //ReefAngel.StandardLights( Port2,18,20,0,1 );
    //white light, on 4:00 PM, off 9:00 PM, 5 hours
    ReefAngel.StandardLights( Port2,16,0,21,0 );
    //skimmer delay
    ReefAngel.Relay.DelayedOn( Port4,10 );
    ReefAngel.SingleATO( true,Port8,240,0 );
    ReefAngel.Portal( "Dugong" );
    int x,y;
    // Salinity
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,15,66, "SAL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, ReefAngel.Params.Salinity );
Try this:
double SalCompensation=0;
  //skimmer delay
  int x,y;
  // Salinity
  if (ReefAngel.TempSensor.unit)
    SalCompensation=ReefAngel.Params.Salinity/(1+((ReefAngel.Params.Temp[T1_PROBE]-250)*0.0024));
    SalCompensation=ReefAngel.Params.Salinity/(1+((ReefAngel.Params.Temp[T1_PROBE]-770)*0.001333));
  ReefAngel.LCD.DrawText( COLOR_DARKKHAKI,DefaultBGColor,39,66, round(SalCompensation) );
