wifi
wifi
i just got my new controller in the mail today so im trying to hook the wifi up, it tells me to add the code in arduino, i have no idea how to code this is the first time i looked at the coding and wouldnt even know where to add it if i did know how to code can someone please help me out thanks
Re: wifi
Just to make sure we are talking about the same wifi utility, you are using the same one shown in this thread, right??
http://forum.reefangel.com/viewtopic.php?f=15&t=345
wifi
Nope DDNS is a dynamic IP address server.
So no matter what IP address your service provider assigns you -- you will just be able to go to link and it will take you to your reefangel.
This is if you want to use your reefangel outside of your home wifi network.
Re: wifi
Remove the plastic bottle in the tip of the ph probe.
Connect it in the controller.
Place it in your sump.
If you find the readings are not correct, you will need to calibrate.
You can find info on calibration inside the manual, but pretty easy. Push the joystick and go to ph calibration.
You will need ph7 and ph10 calibration solutions.
Place it in ph7 and wait and push ok button.
Repeat for ph10.
That's it.
Repeat for ph10.
That's it.
