Preloaded code and change...
baroutas
- Contact:
Re: Preloaded code and change...
I check the driver with AA 1,5 V and 9V batteries and again the same voltage to the led (11,7) V.
The voltage won't change.
It needs to be at about what you are seeing or it would go below the forward voltage and you wouldn't have enough voltage to power the LEDs.
What needs to change is the current. As you apply more or less voltage on the dimming input, the average current increases or decreases making it go brighter or darker.
Most people use only one string or 2 max. You are the first one doing it with several strings.
I would suggest you contact the manufacturer of the driver and check with them.
baroutas
- Contact:
I send mail to the Mean Well. We will see..... Thanks!!
baroutas
- Contact:
Roberto! Today i use controller testter code in my RA and my led dimming normal (sun rise)! BUT... with Wizard code doesn't work why? Is that a bug?
baroutas
- Contact:
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port7Bit | Port8Bit;
InternalMemory.OverheatTemp_write( 350 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1,278,280 );
ReefAngel.StandardFan( Port2,300,310 );
ReefAngel.StandardLights( Port3,13,50,22,0 );
ReefAngel.StandardLights( Port4,15,30,19,0 );
ReefAngel.DosingPumpRepeat( Port5,0,1240,10 );
ReefAngel.StandardLights( Port6,20,30,23,59 );
ReefAngel.PWM.SetDaylight( PWMSlope(14,0,21,0,0,100,2,0) );
ReefAngel.PWM.SetActinic( PWMParabola(20,0,23,59,0,100,0) );
ReefAngel.Portal( "xxxxxx" );
This line is telling the controller to go from 0 to 100 in 2 minutes.
Try a longer period like 60 minutes:
ReefAngel.PWM.SetDaylight( PWMSlope(14,0,21,0,0,100,60,0) );
baroutas
- Contact:
baroutas
- Contact:
Ιf I by dimming expansion module i will need and dimmable led driver, or the module work like led driver?
The ports on the dimming module are just like ap and dp on the relay box...yes you'll need a driver still.
baroutas
- Contact:
Hi again! If my diming port output voltage are 1-10V (during the port operation) then my RA is analog signal?
And if is 10V (during the port operation) stabilization then my RA is PWM?
baroutas
- Contact:
And something else. Τhe PWM led driver work with analog signal and the opposite??
http://www.reefangel.com/Product_PWMvsAnalog.aspx
When measured with a standard multimeter, you can't tell which signal you have.
They both show the same voltage. You need a scope to see the signal.
The drivers will work with another signal, but you won't get a very good dimming linearity. It's best to use the correct one.
baroutas
- Contact:
Ok! I understand!!!!Thanks
