Hi Guys,
I don't have an RA but i'm having some trouble with this pump...
My controler burned up 4 days after i connected the pump, so its not working. Tried to plug an AC/DC converter to reduce the noise and run the thing at 22V but the converter was probably a bad piece of equipment and it burned the controler...
When i plug everything know i Have(on the output to the pump):
- +24V
- -24V
- 0V (va)
so i have an arduino and started to understand what i could do with it...i've been reading this topic and learned very interesting things, and want to share a little bite more of what i've done so far.
So the arduino PWM signal is digital and non stable, it means i need to build a low pass filter(has Roberto said earlier), so i cant pass a stable(analog) signal to the pump. i've made the coding to 6 modes, here it is(it has not been tested in the pump yet).
So if it helps to code any more functions for you guys... here it goes:
#include <Arduino.h>
Software para controlar bomba WP-40 - 1 canal
Arduino
Bomba WP-40
Transformador
Reset do Arduino faz a função Feed(Para a bomba por 5m) e reinicializa passados esses 5m.
// constantes
const int ModoFuncionamento = 3;
const int PWMPin = 9;
// Variaveis:
int EstadoPulse = 0;
long previousMillis = 0;
unsigned long currentMillis = millis();
// Inicializa PWM
Serial.begin(9600);
pinMode(PWMPin, OUTPUT);
previousMillis = millis();
/* Isto faz uma espera de 5 Minutos (5*60 = 300 Segundos = 300000 Milisegundos quando se faz o reset do arduino) Podem retirar se não quiserem esta funcionalidade, ou optar por colocar um butão e nesse caso a pausa teria que ser feita com milis() e quando pressionado o botão, fazer o delay do tempo que se quiser */
//delay(300000);
/* Pulse(Imax, Imin, MilSegundos) - Modo 1
Recebe de entrada:
Imax: Intensidade máxima do Pulse
Imin: Intensidade Minima depois do pulse
MilSegundos: Nr de MiliSegundos de intervalo entre intesidade Máxima e Minima
O Objectivo é variar directo, sem incremento gradual entre a velocidade máxima e velocidade minima pelo nr de segundos indicado
Ex:
Pulse(255, 100, 500)
A Bomba deveria começar a cerca de 40%(100/255) durante 0,5 Segundos, em seguida faz 100% durante 0,5 Segundos
void Pulse(int Imax, int Imin, int MiliSegundos)
if(currentMillis - previousMillis > MiliSegundos) {
previousMillis = currentMillis;
if(EstadoPulse==0){
analogWrite(PWMPin, Imax);
EstadoPulse = 1;
} else {
analogWrite(PWMPin, Imin);
EstadoPulse = 0;
/* RampUp(IntMin, IntMax, Increm, Percent) - Modo 2
Recebe de entrada:
IntMin: Intensidade Inicial
IntMax: Intensidade Final
Increm: Nr de MiliSegundos de intervalo entre intesidade
O Objectivo é variar directo com incremento gradual entre a intensidade minima e máxima, com Increm segundos de intervalo entre o incremento
Ex:
RampUp(50, 225, 500, 15)
A Bomba faria:
Começa nos 20% e fica durante 0,5 Seg
Incrementa 15 ao PWM(65/255) ficando a 25% durante 0,5 Seg
Vai incrementando 5% durante 0,5 Seg até chegar a 88%(225/255)
void RampUp(int IntMin, int IntMax, int Increm, int Percent) {
int ValorPwm = IntMin;
analogWrite(PWMPin, ValorPwm);
do
if(currentMillis - previousMillis > Increm) {
if(ValorPwm > IntMax) {
ValorPwm = IntMax;
ValorPwm = ValorPwm + Percent;
while(ValorPwm < IntMax && ValorPwm >= IntMin);
/* RampDown(IntMin, IntMax, Increm, Percent) - Modo 2
Recebe de entrada:
Ex:
A Bomba faria:
void RampDown(int IntMin, int IntMax, int Increm, int Percent) {
int ValorPWM = IntMax;
analogWrite(PWMPin, ValorPWM);
do
if(ValorPWM < IntMin) {
ValorPWM = IntMin;
ValorPWM = ValorPWM - Percent;
while(ValorPWM <= IntMax && ValorPWM > IntMin);
Modo a utilizar dentro do ReefCrazy - Faz nX Pulse
void PulseSingle(int Imax, int MiliSegundos, int NrTimes)
int Contador = 0;
do {
Contador = Contador + 1;
delay(MiliSegundos);
analogWrite(PWMPin, 0);
delay(100);
while (Contador <= NrTimes);
/* ReefCrazy(IntMin, IntMax, SegMud) - Modo 3
Recebe de Entrada:
Intensidade Minima: Intensidade minima a que a bomba Roda
Intensidade Máxima: Intensidade Máxima a que a bomba roda
Segundos entre as mudanças: Segundos até mudança de modo aleatório
void ReefCrazy(int IntMin, int IntMax, int SegMud)
int RNumber = random(IntMin, IntMax);
int MidleR = (IntMin + IntMax) / 2;
if(RNumber > (MidleR - 20) && RNumber < (MidleR + 20)) {
PulseSingle(200, 500, 3);
if(RNumber > MidleR) {
RampDown(IntMin, MidleR, 500, 15);
RampUp(MidleR, IntMax, 500, 15);
/* Modo 4
Sem parametros de entrada, sobe dos 0 aos 125PWM, faz Pulse 2X, continua a subir aos 255;
Começa a descer dos 255 até 125, faz pulse, e continua até 0;
void JumpingHorse()
RampUp(0, 125, 200, 5);
PulseSingle(200, 500, 2);
RampUp(125, 255, 200, 5);
RampDown(125, 255, 200, 5);
RampDown(0, 125, 200, 5);
/* Modo 5
- Nutrient Export Mode(5 Pulses a 0,5s, muito pequenos, mais 5 maiores, pulse grande para fazer onda, e o processo de pulses inverso).
void NutrientZero()
PulseSingle(125, 500, 5);
PulseSingle(225, 500, 5);
PulseSingle(255, 1000, 1);
/* Modo Desligar - Modo 6 Para fazer por exemplo manutenção ao aquario, fica preparado para quem usar botão*/
void Desligar()
void loop(){
if (ModoFuncionamento == 1) {
Pulse(235, 50, 500);
if (ModoFuncionamento == 2) {
RampUp(50, 225, 500, 15);
RampDown(50, 225, 500, 15);
if (ModoFuncionamento == 3) {
ReefCrazy(50, 225, 500);
if (ModoFuncionamento == 4) {
JumpingHorse();
if (ModoFuncionamento == 5) {
NutrientZero();
if (ModoFuncionamento == 6) {
Desligar();
So, know i have something that i'm willing to understand... my electronics knowledge comes from 1998 at college...
But for what i understood, RA is a lot similar to Arduino(having much more functions and open source).
In order to connect my arduino to the pump, i only need to plug the pwm to the low pass filter and the output of the LowPassFilter to the va line, am i correct?
I'm sorry, i know that you guys don't have an arduino, have a reef angel, but if we could share somethings between eachother, maybe it's easier
BTW, the code hasn't been tested yet(it was in a debugger, but not in the arduino), so it might have some other issue...i'm going to buy material today to test it with leds first and build my LowPass Filter.
Question is, in order to test the va line(without the arduino), is there an easy way so i can pass 3V to the pump? A small battery maybe?
Thanks in advance, and once again i'm sorry to stop by a reef angel dedicated forum with doubts on a diferent platform...
