pc wont connect
the2ndtinman
pc wont connect
Just recieved my long awaited RA today, opened it and looked everything over, everything looks good.
Now my problem, I cannot get my PC to pick it up when it is hooked up through USB. It doesnt seem right to me but maybe it is, i have to have the head unit hooked up to the relay box and the relay box plugged in for the head unit to turn on, i would have thought if I plugged in the usb cable to the computer and the 6 wire cord into the head unit it would power it up. Maybe not.
Any help would be great and im sure I will have more questions later.
dbmet
pc wont connect
You need to have the head unit plugged into the relay box, and the relay box plugged into the wall.
the2ndtinman
Re: pc wont connect
Yes, I have done that but the pc won't recognize that the ra is plugged in via usb
Sent from my EVO using Tapatalk 2
the2ndtinman
Re: pc wont connect
core.a(main.cpp.o): In function `main':
C:\Program Files (x86)\Reef Angel Controller\hardware\arduino\cores\arduino/main.cpp:11: undefined reference to `setup'
C:\Program Files (x86)\Reef Angel Controller\hardware\arduino\cores\arduino/main.cpp:14: undefined reference to `loop'
is what I get when i try and upload to get stock program
Re: pc wont connect
It looks like you have no code at all.
This error happens when you are trying to upload a blank sketch.
the2ndtinman
Re: pc wont connect
Yes, during install of the program I never got the message saying drivers were installed even after waiting for a half hour.
Re: pc wont connect
Check your device manager. Do you have a USB Serial Adapter under COM & LPT Ports?
the2ndtinman
Re: pc wont connect
Yes
the2ndtinman
Re: pc wont connect
Crap.... I lied I think..... All it says is usb serial port(com3)
Re: pc wont connect
Yes, it is correct...
COM3 is the serial port you will use to communicate with the controller.
Drivers are installed correctly.
the2ndtinman
Re: pc wont connect
So what am I doing wrong?
the2ndtinman
Re: pc wont connect
It doesn't say what's is connected just what port it is.
Re: pc wont connect
It already did.
Your USB-TTL cable drivers are already installed correctly.
Windows doesn't see the controller. It only sees the cable and you communicate to the controller through the cable.
It's a USB-TTL cable from FTDI: http://www.ftdichip.com/Products/Cables ... Serial.htm
Now, you need to upload your code. Either copy one of the existing ones, use one of the example codes or generate one with the wizard.
the2ndtinman
Re: pc wont connect
I've tried making a scetch with wizard and when I try and upload it I get a bunch of errors
the2ndtinman
Re: pc wont connect
Yes give me just I while
the2ndtinman
Re: pc wont connect
Watchdog Timer
Version Menu
Dimming Signal
Custom Main Screen
Relay Expansion Module
PH Expansion Module
Standard Menu
Binary sketch size: 29,270 bytes (of a 30,720 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega328p -cstk500v1 -P\\.\COM3 -b57600 -D -Uflash:w:C:\Users\NALOGS~1\AppData\Local\Temp\build1723728085333315681.tmp\sketch_apr19c.cpp.hex:i
Using Port : \\.\COM3
Using Programmer : stk500v1
Overriding Baud Rate : 57600
avrdude: Send: 0 [30] [20]
avrdude: Recv: 3 [33]
avrdude: stk500_getsync(): not in sync: resp=0x33
avrdude done. Thank you.
Watchdog Timer
Version Menu
Dimming Signal
Custom Main Screen
PH Expansion Module
Standard Menu
the2ndtinman
Re: pc wont connect
and here is the code
ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1,551,815 );
ReefAngel.StandardATO( Port2,60 );
ReefAngel.StandardLights( Port3,15,0,0,0 );
ReefAngel.WavemakerRandom( Port5,4,100 );
ReefAngel.WavemakerRandom( Port6,24,100 );
int x,y;
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 14, ReefAngel.Params );
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,54, "PHE:" );
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,54, ReefAngel.Params.PHExp );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 74, TempRelay );
// Relay Expansion
ReefAngel.LCD.DrawOutletBox( 12, 97, TempRelay );
// Date and Time
int x,y;
// Parameters
// pH Expansion
// Main Relay Box
// Relay Expansion
// Date and Time
the2ndtinman
Re: pc wont connect
just the regular not the plus
Re: pc wont connect
Make sure you have Reef Angel controller w/ optiboot selected under Tools->Board
