New Reef Angel Blank Screen
zveck
Brand new out of the box, screen backlight is on and the controller seems to be functioning and controllable from the client but the screen remains blank. I tried pwr cycle, cable reseating, restore to factory mode, joystick moving and pressing, lcd reseating, lcd flex solder inspection. Ran the wizard to change code, then back to factory settings... still blank lcd. Any ideas?
Re: New Reef Angel Blank Screen
The new libraries will fix this issue.
It's related to this:
http://forum.reefangel.com/viewtopic.php?f=2&t=3111
I was supposed to release yesterday, but got caught up in another thing.
It will go out tonight.
zveck
InternalMemory.LCDID_write(0);
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardFan( Port1,778,781 );
ReefAngel.StandardHeater( Port2,770,775 );
ReefAngel.StandardLights( Port3,1,0,12,0 );
ReefAngel.StandardATO( Port4,60 );
ReefAngel.WavemakerRandom( Port5,180,360 );
ReefAngel.WavemakerRandom( Port6,240,360 );
ReefAngel.Relay.DelayedOn( Port8,2 );
ReefAngel.PWM.SetDaylight( PWMParabola(13,0,0,0,11,50,11) );
ReefAngel.PWM.SetActinic( PWMParabola(12,0,1,0,15,95,15) );
returns this error
'class InternalEEPROMClass' has no member named 'LCDID_write'
returns this error
Its getting fixed tonight. Take a look at robertos post above
zveck
Patience = class for which I seemed to have played hookie...
