ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit;
ReefAngel.Relay.DelayedOn( Port3 );
ReefAngel.StandardHeater( Port4 );
ReefAngel.DayLights( Port7 );
ReefAngel.PWM.Channel0PWMParabola();
ReefAngel.PWM.Channel1PWMParabola();
// Read memory for RF Wave Settings and use for Tunze/Jaebo
int mode=InternalMemory.RFMode_read();
int speed=InternalMemory.RFSpeed_read();
int duration=InternalMemory.RFDuration_read();
// Change this to what you want your min/max based on vortech speed
// This is for those functions that take both, but only one memory slot.
int minOffset=5;
int maxOffset=10;
int min=speed-minOffset;
int max=speed+maxOffset;
switch (mode) {
case Lagoon:
//lagoon
ReefAngel.PWM.SetDaylight( SineMode(min,max,duration,true) );
// ReefAngel.PWM.SetActinic( SineMode(min,max,duration,false) );
break;
case ReefCrest:
//reefcrest
ReefAngel.PWM.SetDaylight( ReefCrestMode(speed,duration,true) );
// ReefAngel.PWM.SetActinic( ReefCrestMode(speed,duration,false) );
break;
case NutrientTransport:
//nutrient transport
ReefAngel.PWM.SetDaylight( NutrientTransportMode(min,max,duration,true) );
// ReefAngel.PWM.SetActinic( NutrientTransportMode(min,max,duration,false) );
break;
ReefAngel.Portal( "topjimmy" );
int x,y;
// Dimming Expansion
x = 15;
y = 2;
for ( int a=0;a<6;a++ )
if ( a>2 ) x = 75;
if ( a==3 ) y = 2;
y += 10;
// Parameters
// Main Relay Box
// Date and Time
Is there anything in that sketch that would keep that port on?
