byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
//Return 1
//Blue LED and Fans 2
//White LED 3
//Alk 4
//Powerhead 5
//Heater 6
#define ATO 7
//Skimmer 8
#define wifi
ReefAngel.PHMin=200;
ReefAngel.PHMax=807;
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port7Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.StandardLights( Port2,9,0,21,0 );
ReefAngel.StandardLights( Port3,9,0,21,0 );
ReefAngel.StandardHeater( Port6,760,770 );
// Calculate your regular sunrise/sunset PWM value
ActinicPWMValue=PWMSlope(9,0,21,0,14,100,14,ActinicPWMValue);
DaylightPWMValue=PWMSlope(9,0,21,0,14,100,14,DaylightPWMValue);
CheckCloud();
//Alk Dosing Pump 1 Minute Every 45 Minutes
if (now()%2700<60) ReefAngel.Relay.On(Port4); else ReefAngel.Relay.Off(Port4);
//Powerhead On Every 4 Hours With 30 Min Pause
if (now()%1800<12600) ReefAngel.Relay.On(Port5); else ReefAngel.Relay.Off(Port5);
//Heater Control on at 77F and off at 78F
ReefAngel.StandardHeater(Port6,770,780);
ReefAngel.SingleATO(true,ATO,300,0);
void CheckCloud()
#define Clouds_Every_X_Days 2
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(11,30)
#define End_Cloud_Before NumMins(18,30)
#define Lightning_Change_per_Cloud 50
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if ((cloudstart/60)>=10) x=11; else x=17;
if ((cloudstart%60)>=10) x=29; else x=35;
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
