bool ReefAngelClass::SetupOption(int &v, int &w, int &x, int &y, int rangemin, int rangemax, byte maxdigits, char* unit, char* subunit, char* title, char* prefix1,
char* prefix2, char* prefix3, char* prefix4) {
// return true to save value stored in out in memory
enum choices {
OPT1, OPT2, OPT3, OPT4, OK, CANCEL
byte sel = OPT1;
bool bSave = false;
bool bDone = false;
bool bRedraw = true;
bool bDrawButtons = true;
byte offset = 50;
ClearScreen(DefaultBGColor);
LCD.DrawText(DefaultFGColor, DefaultBGColor, MENU_START_COL, MENU_START_ROW, title);
// prefix for each option
LCD.DrawText(DefaultFGColor, DefaultBGColor, MENU_START_COL, MENU_START_ROW * 3, prefix1);
LCD.DrawText(DefaultFGColor, DefaultBGColor, MENU_START_COL, MENU_START_ROW * 5, prefix2);
LCD.DrawText(DefaultFGColor, DefaultBGColor, MENU_START_COL, MENU_START_ROW * 7, prefix3);
LCD.DrawText(DefaultFGColor, DefaultBGColor, MENU_START_COL, MENU_START_ROW * 9, prefix4);
do {
wdt_reset();
if (bRedraw) {
switch (sel) {
case OPT1:
LCD.DrawOption(v, 1, MENU_START_COL + offset, MENU_START_ROW * 3, unit, subunit, maxdigits);
if (bDrawButtons) {
LCD.DrawOK(false);
LCD.DrawCancel(false);
break;
case OPT2:
LCD.DrawOption(v, 0, MENU_START_COL + offset, MENU_START_ROW * 3, unit, subunit, maxdigits);
LCD.DrawOption(y, 1, MENU_START_COL + offset, MENU_START_ROW * 5, unit, subunit, maxdigits);
if (bDrawButtons) {
LCD.DrawOK(false);
break;
case OPT3:
LCD.DrawOption(v, 0, MENU_START_COL + offset, MENU_START_ROW * 5, unit, subunit, maxdigits);
LCD.DrawOption(y, 1, MENU_START_COL + offset, MENU_START_ROW * 7, unit, subunit, maxdigits);
if (bDrawButtons) {
LCD.DrawOK(false);
break;
case OPT4:
LCD.DrawOption(v, 0, MENU_START_COL + offset, MENU_START_ROW * 7, unit, subunit, maxdigits);
LCD.DrawOption(y, 1, MENU_START_COL + offset, MENU_START_ROW * 9, unit, subunit, maxdigits);
if (bDrawButtons) {
LCD.DrawOK(false);
break;
case OK:
if (bDrawButtons) {
LCD.DrawOption(y, 0, MENU_START_COL + offset, MENU_START_ROW * 9, unit, subunit, maxdigits);
LCD.DrawOK(true);
break;
case CANCEL:
if (bDrawButtons) {
LCD.DrawOK(false);
LCD.DrawCancel(true);
break;
bRedraw = false;
bDrawButtons = false;
} // if bRedraw
if (Joystick.IsUp()) {
bRedraw = true;
if (sel == OPT1) {
v++;
if (v > rangemax || v < rangemin) {
v = rangemin;
else if (sel == OPT2) {
w++;
if (w > rangemax || w < rangemin) {
w = rangemin;
else if (sel == OPT3) {
x++;
if (x > rangemax || x < rangemin) {
x = rangemin;
else if (sel == OPT4) {
y++;
if (y > rangemax || y < rangemin) {
y = rangemin;
if (Joystick.IsDown()) {
bRedraw = true;
if (sel == OPT1) {
v--;
if (v < rangemin || v > rangemax) {
v = rangemax;
w--;
if (w < rangemin || w > rangemax) {
w = rangemax;
x--;
if (x < rangemin || x > rangemax) {
x = rangemax;
y--;
if (y < rangemin || y > rangemax) {
y = rangemax;
if (Joystick.IsRight()) {
bRedraw = true;
bDrawButtons = true; // only redraw the buttons if we are moving right or left
// move right, if we are on cancel, wrap around to opt1
sel++;
if (sel > CANCEL) {
sel = OPT1;
if (Joystick.IsLeft()) {
bRedraw = true;
// move left, if we are on opt1, wrap around to cancel
sel--;
if (sel > CANCEL) {
sel = CANCEL;
if (Joystick.IsButtonPressed()) {
// only break when button pressed on ok or cancel
if (sel == OK) {
bDone = true;
bSave = true;
else if (sel == CANCEL) {
bDone = true;
while (!bDone);
// return true saves the value, false ignores the value
return bSave;
