Wave patterns
coolbird
Re: Wave patterns
Post by coolbird »
Can they go to zero then?
Re: Wave patterns
Not with this function.
We can code it differently to get the same results in order to go down to zero.
coolbird
Re: Wave patterns
Post by coolbird »
rimai wrote:Not with this function.
Thanks. For what I have in mind that would be very useful 8-)
Re: Wave patterns
Use this instead then:
  byte Jebao=(now()%(20*2)<20?0:30);
  ReefAngel.PWM.SetActinic(Jebao);
  ReefAngel.PWM.SetDaylight(Jebao==0?30:0);
coolbird
Re: Wave patterns
Post by coolbird »
rimai wrote:Use this instead then:
Sorry Roberto how does that code work the parameters, just so I can tweak it
Dave
Re: Wave patterns
This is easier:
  #define JebaoDuration   20
  #define JebaoMin        0
  #define JebaoMax        30
  byte Jebao=(now()%(JebaoDuration*2)<JebaoDuration?JebaoMin:JebaoMax);
  ReefAngel.PWM.SetDaylight(Jebao==JebaoMin?JebaoMax:JebaoMin);
Change what's in the define section
coolbird
Re: Wave patterns
Post by coolbird »
rimai wrote:This is easier:
  #define JebaoMin        0
  #define JebaoMax        30
And what do I do about the lines I have already put in? Sorry its national daft question day in the UK :-)
Re: Wave patterns
Remove them and replace with the post above
coolbird
Re: Wave patterns
Post by coolbird »
rimai wrote:Remove them and replace with the post above
OK will give it a try and let you know
Dave
Re: Wave patterns
Thanks for contributing!!!
If I don't hear anyone else, I'll lower it to 25 on the next update.
coolbird
Re: Wave patterns
Post by coolbird »
  #define JebaoMin        0
  #define JebaoMax        30
That worked brilliantly and taught me a bit too, do you thnk that dropping the speed to zero over long periods could cause wear on the pumps?
I remember having 2 sicce voyager pumps and over a period of time they would not start up and you ended up having to change the impellers.
Just a thought but this is working fine until I can work out a wave pattern that suits the tank better.
regards
Dave
Seedlessone
Re: Wave patterns
Post by Seedlessone »
Is there a way to have a pattern that I can put a group of speeds and to change every second? So for example: 87,76,100,91,65,46,92, etc. and also have it change speeds every second? If so how many numbers could I use?
Re: Wave patterns
Yes, this should do it...you'll have to put the sequence you want and change the array size and rollover number to match.
static int speed=0;
byte speeds[4] = { 93, 81, 72, 63 };
if (millis()%1000=0) speed++;
if (speed>=4) speed=0;
ReefAngel.PWM.SetActinic(speeds[i]);
coolbird
Re: Wave patterns
Post by coolbird »
jerry27 wrote:
coolbird wrote: That worked brilliantly and taught me a bit too, do you thnk that dropping the speed to zero over long periods could cause wear on the pumps?
regards
Dave
since theyre DC pumps they start properly everytime and the wear shouldnt be an issue. if youre worried about it just drop it to around 20 or so. the water movement at that speed for mine is not even noticable but they keep turning.
if youre using the standard menu and you want to experiment with how low your pumps will go and find the minimum that they will turn back on, use this
  ReefAngel.PWM.Override(OVERRIDE_DAYLIGHT, InternalMemory.LEDPWMDaylight_read());
  ReefAngel.PWM.Override(OVERRIDE_ACTINIC, InternalMemory.LEDPWMActinic_read());
comment out your wave patterns then go to lights>led pwm and the "ap:" will control one pump and the "dp:" will control another.
you can comment out an entire block of code by using /**/.
code
code
code
instead of line by line using //
if you give it a shot post your minimums so roberto can better adjust the libraries.
Will give it a go and post. Thanks
coolbird
Re: Wave patterns
Post by coolbird »
regards
Dave
code
code
code
Re: Wave patterns
rimai wrote:Thanks for contributing!!!
Roberto, can we make this number a define or mem location that can be overidden? I'm using these functions to feed the Custom mode on my mp40s and don't need to be constrained at all though I wouldnt mind setting it to 10 or something..
Other option is to set the default but overide the fuction so we can pass the constrain as an argument?
I can submit a pull request but not sure what the preference would be..
Re: Wave patterns
On second thought it would probably be best to override the function and make the current default to whatever number works good for Jaebo.
Re: Wave patterns
Actually, I'm thinking I'm just going to remove the constrain.
It seems that you can only get a wave if you set the min speed to 0.
Re: Wave patterns
Works for me.
tomek77pl
Re: Wave patterns
Post by tomek77pl »
Hi Is it possible to have a both wave patters for one pump? I want it to run nutrition export for 2 hrs a day then go back into the reef crest mode. Is this possible? If yes how can this be done? Thanks :)
ReeferBee
Re: Wave patterns
Post by ReeferBee »
tomek77pl wrote:Hi Is it possible to have a both wave patters for one pump? I want it to run nutrition export for 2 hrs a day then go back into the reef crest mode. Is this possible? If yes how can this be done? Thanks :)
Yep you can. Which wave patterns are you trying to run, and at what times?
Here's an example. I have different modes run throughout the day.
if (hour()>=8 && hour()<11)
  vtechmode=6;
  ReefAngel.PWM.SetDaylight( TidalSwellMode(40,true) ); // Tidal Swell at 40% on sync mode
  ReefAngel.PWM.SetActinic( TidalSwellMode(40,false) ); // Tidal Swell at 40% on anti-sync mode
else if (hour()>=11 && hour()<12)
  vtechmode=2;
  ReefAngel.PWM.SetDaylight( ReefCrestMode(50,20,true) ); // ReefCrest at 50% + - 20 on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(50,20,false) ); // ReefCrest at 50% + - 20 on anti-sync mode
else if (hour()>=12 && hour()<13)
  vtechmode=0;
  ReefAngel.PWM.SetDaylight( millis()%1000>800?80:0); // WaveMode on sync mode
  ReefAngel.PWM.SetActinic( ElseMode(70,30,true) ); // ElseMode at 70  on anti-sync mode
else if (hour()>=13 && hour()<14)
  vtechmode=2;
  ReefAngel.PWM.SetDaylight( ReefCrestMode(70,20,true) ); // ReefCrest at 70% + - 20 on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(70,20,false) ); // ReefCrest at 70% + - 20 on anti-sync mode
else if (hour()>=15 && hour()<18)
  vtechmode=0;
  ReefAngel.PWM.SetDaylight( ElseMode(70,30,true) ); // Else on sync mode
  ReefAngel.PWM.SetActinic( millis()%1000>800?80:0); // Wave on anti-sync mode
else if (hour()>=18 && hour()<21)
  vtechmode=5;
  ReefAngel.PWM.SetDaylight( NutrientTransportMode(77,90,3000,true) ); // Nutrient Transport on sync mode
  ReefAngel.PWM.SetActinic( NutrientTransportMode(77,90,3000,false) ); //   Nutrient Transport on anti-sync mode
else if (hour()>=21 && hour()<24)
  vtechmode=1;
  ReefAngel.PWM.SetDaylight( millis()%1000>800?70:0); // Wave on sync mode
  ReefAngel.PWM.SetActinic( ElseMode(70,30,true) ); // Else on anti-sync mode
  vtechmode=4;
  ReefAngel.PWM.SetDaylight( LongPulseMode(40,40,10,true) ); // Long pulse at 40% with 10s pulse on syncy mode
  ReefAngel.PWM.SetActinic( LongPulseMode(40,40,10,false) ); // Long pulse at 40% with 10s pulse on on anti-sync mode
    ReefAngel.PWM.SetActinic(0);
    ReefAngel.PWM.SetDaylight(0);
Barry
Current tank info: 150g mixed reef
"Some of the worst mistakes of my life were hair cuts" -Jim Morrison
tomek77pl
Re: Wave patterns
Post by tomek77pl »
Lets say I want nutrition export to run from 4pm-6pm and reef crest to run the remaining 22 hrs. This is for the jeabo pump.
ReeferBee
Re: Wave patterns
Post by ReeferBee »
Try this, although Nutrient export needs to be ran 2.5 hours to complete the mode.
if (hour()>=16 && hour()<18)
else if (hour()>=18 && hour()<16)
You can change the values of the modes too, if its too much flow
Barry
tomek77pl
Re: Wave patterns
Post by tomek77pl »
Thank you!!! I just made it for 3 hrs instead of 2 so at least it finished one cycle of nutrition export.
AnesthDoc
Re: Wave patterns
Post by AnesthDoc »
Barry,
A question for you.
I am just beginning to learn the arduino language and at the moment only using the Wizard for the basic settings.
If I want to use your wave pattern code (different waves throughout the day), I understand I will have to cut and paste the code in the wizard where it says "your custom code goes below this line" but do I need to remove any lines from the wizard code or make any other changes?
I recall a similar situation where a member suggested to remove a code line before using a custom wave pattern code.
Appreciate your help.
AnesthDoc
Re: Wave patterns
Post by AnesthDoc »
Can someone else help me?
Re: Wave patterns
Did you try to use the code he posted?
ReEfnWrX
Re: Wave patterns
Post by ReEfnWrX »
Anesthdoc,
His code states specific times during the day, and what wave pattern runs during those times. The first line is an if statement everything following that for different times is an else if statement.
Add as many else if statements as you want. Make sure the times don't overlap. Also, he made a mistake in his code. For the last code in the day, let's say you want it to run between 11pm and 8 am you would use || (or) instead of && (and). the time cannot be greater than 11pm and less than 2am as the RA logic only views a 24 hour time period. So you would use
else if (hour()>=18 || hour()<16)
Also, I find it easier to always use >= and always use just < by itself.
if you want to add in minutes you could do this
if ((hour()>=18 && minute()>=30) || (hour()<16 && minute()==0)) // >=6:30pm ||(OR) <4:00pm
Wave patterns
That last example with minute() will not work. It will only cover 18:30-18:59 then 19:30-19:59 and so on. Or you'll need another || hour()>=19
ReEfnWrX
Re: Wave patterns
Post by ReEfnWrX »
Good catch, I wrote that real quick off the top of my head. I just looked at my old code and I did have the additional || hour()
