No temperature readings
mvwise
Post by mvwise »
Hi,
I've just uploaded my code to a new controller (after loading the initial memory settings) and I'm getting 0 for my Temp 1 and Error for my Temp 2 and Temp 3 readings. This is the same code that I have been using on the other units, so I don't think it's the code, unless something changed in the recent libraries. Could something be wrong with the unit?
Here is the code:
// This version updated for v1.0.3 or later
The following features are enabled for this File:
#define DisplayImages
#define OverheatSetup
#define DateTimeSetup
#define VersionMenu
#define DirectTempSensor
#define DisplayLEDPWM
#define wifi
#define SaveRelayState
#define WDT
#define PWMEXPANSION
#define CUSTOM_MAIN
#define COLORS_PDE
#define SALINITYEXPANSION
#define RFEXPANSION
#define FONT_8x8
#define FONT_8x16
Ports assignment:
Port1 - Fuge Light
Port2 - Avast ATO
Port3 - Heater(s)
Port4 - Kalk Reactor
Port5 - Avast Schwabble
Port6 - Closed Loop Pump
Port7 - Skimmer
Port8 - Return Pump
//--------------------------------------------------- Start of Global Variables ---------------------------------------------------
// Globals Needed for RF Mode on Custom Menu
byte vtmode;
byte vtspeed;
// Globals Needed for Params on Custom Main
byte x,y;
int v;
// Globals Needed for RF Mode on Custom Main
byte vtechmode;
byte vtechspeed;
boolean bFeeding=false;
//------------------------------------------------------ End of Global Variables --------------------------------------------------
//----------------------------------------------------------- Custom Menu ---------------------------------------------------------
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding";
prog_char menu1_label[] PROGMEM = "Water Change Pause";
prog_char menu2_label[] PROGMEM = "Vortech Mode";
prog_char menu3_label[] PROGMEM = "Vortech Speed";
prog_char menu4_label[] PROGMEM = "Lights On";
prog_char menu5_label[] PROGMEM = "Lights Off";
prog_char menu6_label[] PROGMEM = "Overheat Clear";
prog_char menu7_label[] PROGMEM = "PH Calibration";
prog_char menu8_label[] PROGMEM = "Salinity Calibration";
menu0_label, menu1_label, menu2_label,
menu3_label, menu4_label, menu5_label,
menu6_label, menu7_label, menu8_label
void MenuEntry1()
     ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
     vtmode++;
     vtechmode++;
     if (vtmode>6)
       vtmode=0;
       vtechmode=0;
     InternalMemory.RFMode_write(vtmode); // Set the Internal Memory Setting for RF Mode
     ReefAngel.RF.SetMode(vtmode, InternalMemory.RFSpeed_read(), InternalMemory.RFDuration_read());
void MenuEntry4()
     vtspeed+=10;
     vtechspeed+=10;
     if (vtspeed>100)
       vtspeed=0;
       vtechspeed=0;
     InternalMemory.RFSpeed_write(vtspeed); // Set the Internal Memory Setting for RF Speed
     ReefAngel.RF.SetMode(InternalMemory.RFMode_read(), vtspeed, InternalMemory.RFDuration_read());
void MenuEntry5()
     ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
     ReefAngel.Relay.Write();
void MenuEntry6()
     ReefAngel.Relay.RelayMaskOn = 0;
void MenuEntry7()
     ReefAngel.OverheatClear();
void MenuEntry8()
     ReefAngel.SetupCalibratePH();
void MenuEntry9()
     ReefAngel.SetupCalibrateSalinity();
//--------------------------------------------------------- End Custom Menu -------------------------------------------------------
//---------------------------------------------Custom Main for PWM Expansion Module------------------------------------------------
        //Top Banner
        ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 9, 3, "WISEGUYS' REEF", Font8x16);
        ReefAngel.LCD.Clear(DefaultFGColor,3,21,126,21);
        // Display T1 Header Text
        ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,10,25,"Tank");
        char text[7];
        // Display the T1 Temp Value
        ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 4, 35, text, Font8x16);
        // Display the Salinity Header Text
        ReefAngel.LCD.DrawText(COLOR_CRIMSON,255,55,25,"Sal.");
        // Display the Salinity Value
        ReefAngel.LCD.DrawLargeText(COLOR_CRIMSON, 255, 57, 35, text, Font8x16);
        // Display pH Header Text
        ReefAngel.LCD.DrawText(COLOR_INDIGO,255,105,25,"pH");
        // Display pH Value
        ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 94, 35, text, Font8x16);
        //Display Alternate Temp Parameters
        ReefAngel.LCD.DrawText(0,255,8,54,"Sump");
        ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_CORNFLOWERBLUE, 36, 54, 10);
        ReefAngel.LCD.DrawText(0,255,72,54,"Hood");
        ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_CORNFLOWERBLUE, 100, 54, 10);
        // Display EcoSmart Mode Value & Speed %
        ReefAngel.LCD.Clear(DefaultFGColor,3,65,126,65);
        ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 17, 69, "Ecotech Mode");
        ConvertNumToString(text, vtechspeed, 1);
        if (vtechmode == 0)
          ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,1,80,"Constant -  ", Font8x16);
          ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,97,80,text, Font8x16);
          ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,121,80,"%", Font8x16);
        else if(vtechmode == 1)
          ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,1,80,"Lagoon -    ", Font8x16);
          ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,97,80,text, Font8x16);
          ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,121,80,"%", Font8x16);
        else if (vtechmode == 2)
          ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,1,80,"Reef Crest -", Font8x16);
        else if (vtechmode == 3)
          ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,1,80,"Short Pulse-", Font8x16);
          ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,97,80,text, Font8x16);
          ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,121,80,"%", Font8x16);
        else if (vtechmode == 4)
          ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,1,80,"Long Pulse -", Font8x16);
          ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,97,80,text, Font8x16);
          ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,121,80,"%", Font8x16);
        else if (vtechmode == 5)
          ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,1,80,"Nutrient TM-", Font8x16);
          ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,97,80,text, Font8x16);
          ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,121,80,"%", Font8x16);
        else if (vtechmode == 6)
          ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,1,80,"Tidal Swell-", Font8x16);
        else if (vtechmode == 9)
          ReefAngel.LCD.DrawLargeText(COLOR_BLACK,255,1,80,"Night -     ", Font8x16);
          ReefAngel.LCD.DrawLargeText(COLOR_BLACK,255,97,80,text, Font8x16);
          ReefAngel.LCD.DrawLargeText(COLOR_BLACK,255,121,80,"%", Font8x16);
        // Display Main Relay Box
        ReefAngel.LCD.Clear(DefaultFGColor,3,99,126,99);
        ReefAngel.LCD.DrawOutletBox(13, 102, TempRelay);
        //Draw Date & Time
        ReefAngel.LCD.Clear(DefaultFGColor,3,116,126,116);
        ReefAngel.LCD.DrawDate(6, 119);
void DrawCustomGraph()  // Not Used
//------------------------------------------------------ End Custom Main ----------------------------------------------------------
//-------------------------------------------------------- Begin Setup ------------------------------------------------------------
    ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items));  //Intialize Custom Menu
    vtmode=InternalMemory.RFMode_read();
    vtspeed=InternalMemory.RFSpeed_read();
    vtechmode=InternalMemory.RFMode_read();
    vtechspeed=InternalMemory.RFSpeed_read();
    ReefAngel.FeedingModePorts = Port2Bit | Port7Bit | Port6Bit; // Turn off Skimmer, ATO and Close Loop when feeding mode is activated
    ReefAngel.WaterChangePorts = Port2Bit | Port7Bit | Port8Bit; // Turn off Return Pump, Skimmer & ATO when water change mode is actived
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port3Bit;
    ReefAngel.TempProbe = T2_PROBE; // Use T1 probe as temperature and overheat functions
    InternalMemory.OverheatTemp_write( 850 ); // Set the Overheat temperature setting
    ReefAngel.Relay.On(Port8);
    ReefAngel.Relay.On(Port6);
//---------------------------------------------------------- End Setup ------------------------------------------------------------
//--------------------------------------------------------- Begin Loop ------------------------------------------------------------
    // Specific functions
    ReefAngel.Relay.DelayedOn(Port7, 2); // Turn on Port 7 (Skimmer) with 2 minute delay
    ReefAngel.Relay.DelayedOn(Port2, 10); // Turn on Port 2 (Avast ATO) with 10 minute delay
    ReefAngel.StandardLights(Port1,21,0,9,00); //Fuge Light on at night
    ReefAngel.StandardHeater(Port3,770,790); // Standard Heater Using Internal Memory
    ReefAngel.DosingPumpRepeat(Port5,0,360,60); //Turn Schwabble on for 1 minute every 4 hours
    ReefAngel.DosingPumpRepeat(Port4,0,30,30); // Turn Kalk stirer on for 30 seconds every half hour
    // Fan Speed Functions
    signed int HoodFanSpeed;
    HoodFanSpeed=map(ReefAngel.Params.Temp[3],750,1000,25,100); // Calculate Hood Fan speed
    HoodFanSpeed=constrain(HoodFanSpeed,0,100);
    ReefAngel.PWM.SetChannel(0,HoodFanSpeed);
    signed int SumpFanSpeed;
    SumpFanSpeed=map(ReefAngel.Params.Temp[1],750,850,25,100); // Calculate Sump Fan speed
    SumpFanSpeed=constrain(SumpFanSpeed,0,100);
    ReefAngel.PWM.SetChannel(1,SumpFanSpeed);
------------------------------------------------ Start Time-of-Day Based Functions ----------------------------------------------
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ These are the mode numbers for the RF Expansion Module for reference ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
    #define Constant      0
    #define Random1       1 // Lagoonal
    #define Random2       2 // Reef Crest
    #define ShortWave     3
    #define LongWave      4
    #define Smart_NTM     5 // Nutrient Transport Mode
    #define Smart_TSM     6 // Tidal Swell Mode
    #define Feeding_Start 7
    #define Feeding_Stop  8
    #define Night         9
    #define Slave_Start   97
    #define Slave_Stop    98
    #define None          99
    RF Mode      = http://YOURIPADDRESS:2000/mb855,X
    RF Speed     = http://YOURIPADDRESS:2000/mb856,X
    RF Duration  = http://YOURIPADDRESS:2000/mb857,X
//-------------------------------------------------------- Start RF Smart Nutrient Mode After Feeding ---------------------------
  if (hour() >=9  && hour() < 21)
    if (vtechmode == 9)
      ReefAngel.RF.UseMemory=true;
      vtechmode = InternalMemory.RFMode_read();
      vtechspeed = InternalMemory.RFSpeed_read();
    if (ReefAngel.DisplayedMenu==FEEDING_MODE) bFeeding=true;
    if (ReefAngel.DisplayedMenu==DEFAULT_MENU && bFeeding)
      bFeeding=false;
      ReefAngel.Timer[1].SetInterval(600); // Timer for 10min
      ReefAngel.Timer[1].Start();
      ReefAngel.RF.UseMemory=false;
      ReefAngel.RF.SetMode(Smart_NTM,100,6);
      vtechmode = 5;
      vtechspeed = 100;
    if (ReefAngel.DisplayedMenu==DEFAULT_MENU && ReefAngel.Timer[1].IsTriggered())
      vtechmode = 9;
      vtechspeed = 15;
//---------------------------------------------------------- End RF Smart Nutrient Mode After Feeding -----------------------------
    ReefAngel.Portal("mvwise");
//--------------------------------------------------------------- End Loop --------------------------------------------------------
Re: No temperature readings
Can you check this probe the other controller?
Or the other probe in this controller?
Just make sure to reboot the controller after you swap.
mvwise
Post by mvwise »
Thanks - resetting the unit was the key!
