i'm new to the reef angel controller, i ordered it 2 months ago but i have not yet installed it. i've hooked it up to test it and adjust my meanwell drivers for LED fixtures but thats about it.
my plans are to use the RA controller as a wave maker with 4 koralia evo PHs but i only have the singal relay box for now so i would liek to free up the two day light and actinic outlets and keep the moonlight output for my refugium lights. my question is really will the PWM outputs be able to shut my lights off when they are supposed to if i connect my lights to a seperate power bar or do i need to use the dayligh and actinic ports on the relay box to electrically shut the drivers off.
i know some programming will need to be done but i'm a quick learner and hoping someone may already have some coding for this sort of feature
New to RA and question on basic ltg
Re: New to RA and question on basic ltg
If your lights are dimmable then you can dim your lights off. I do mine that way.
thanks colin
