Hi
Trying to get up and running to dose using 2 pumps, (Alk & Ca).
Just received Reefangel and I have no idea what I'm doing, but managed to get temp, pH, lights, fan, and WIFI running... Despite pumps set to run every 6 hrs, they have yet to come on, (I have the discharging into a graduated cylinder to measure volume).
I installed/updated pre-installed code and used wizard to generate :dosing, temp, light dimming etc...
Do you layer codes, ie: wizard generated one over preinstalled code, (like I did)?
Or, format head unit and upload only wizard generated one?
Thanks for any help
Cheers
Help... Im useless! dosing pump woes
Re: Help... Im useless! dosing pump woes
Post your code. Have you tried running the pumps manually and making sure they are working as expected?
Yes, both BRS pumps are brand new. I hooked them up and primed them until liquid came through.
Can my code be directly loaded over preset code?
This is the code I uploaded from wizard, PORT 3&4 for dosers:
InternalMemory.OverheatTemp_write( 815 );
ReefAngel.StandardHeater( Port1,776,780 );
ReefAngel.StandardFan( Port2,783,784 );
ReefAngel.DosingPumpRepeat( Port3,10,360,10 );
ReefAngel.DosingPumpRepeat( Port4,0,360,10 );
ReefAngel.StandardLights( Port5,13,0,22,0 );
ReefAngel.PWM.SetDaylight( PWMSlope(13,0,22,0,1,25,60,1) );
ReefAngel.PWM.SetActinic( PWMSlope(13,0,22,0,0,25,60,0) );
Ha ha, I guess I couldn't see a level because it was only set for 10 sec? The wizard must of not taken my value?
I tried changing the code, I'll see if it works
ReefAngel.AddWifi();
Yeah 10 seconds on the BRS pump is nothing, 30ml broken into 24 doses is 68 seconds every hour. I think the conversion was .0183 ml/second...
