Updated and trouble with code
ReeferBee
Post by ReeferBee »
Ive updated my library and now my code isn't working.
This is my current code, which was working until i just updated. Thanks in advance for any help!
byte vtechmode=0;
    ReefAngel.WaterChangePorts = Port5Bit | Port7Bit | Port8Bit;
    ReefAngel.Relay.On( Port7 );
    ReefAngel.StandardLights( Port1,13,30,18,0 );
    ReefAngel.StandardLights( Port2,13,00,00,00 );
    ReefAngel.DosingPumpRepeat( Port3,0,120,240 );
    ReefAngel.DosingPumpRepeat( Port4,29,120,360 );
    ReefAngel.StandardHeater( Port6,779,785 );
    if (hour()>=8 && hour()<11)
  vtechmode=6;
  ReefAngel.PWM.SetDaylight( TidalSwellMode(50,true) ); // Tidal Swell at 50% on sync mode
  ReefAngel.PWM.SetActinic( TidalSwellMode(50,false) ); // Tidal Swell at 50% on anti-sync mode
else if (hour()>=11 && hour()<12)
  vtechmode=2;
  ReefAngel.PWM.SetDaylight( ReefCrestMode(60,20,true) ); // ReefCrest at 60% + - 20 on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(60,20,false) ); // ReefCrest at 60% + - 20 on anti-sync mode
else if (hour()>=12 && hour()<13)
  vtechmode=2;
  ReefAngel.PWM.SetDaylight( ReefCrestMode(70,20,true) ); // ReefCrest at 70% + - 20 on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(70,20,false) ); // ReefCrest at 70% + - 20 on anti-sync mode
else if (hour()>=13 && hour()<14)
  vtechmode=2;
  ReefAngel.PWM.SetDaylight( ReefCrestMode(80,20,true) ); // ReefCrest at 80% + - 20 on sync mode
  ReefAngel.PWM.SetActinic( ReefCrestMode(80,20,false) ); // ReefCrest at 80% + - 20 on anti-sync mode
else if (hour()>=15 && hour()<18)
  vtechmode=5;
  ReefAngel.PWM.SetDaylight( NutrientTransportMode(77,90,1500,true) ); // Nutrient Transport on sync mode
  ReefAngel.PWM.SetActinic( NutrientTransportMode(77,90,1500,false) ); // Nutrient Transport on anti-sync mode
else if (hour()>=18 && hour()<21)
  vtechmode=2;
  ReefAngel.PWM.SetDaylight( ElseMode(70,30,true) ); // ReefCrest at 70% + - 15 on sync mode
  ReefAngel.PWM.SetActinic( ElseMode(70,30,false) ); // ReefCrest at 70% + - 15 on anti-sync mode
else if (hour()>=21 && hour()<24)
  vtechmode=6;
  ReefAngel.PWM.SetDaylight( millis()%1200>800?80:0); // Tidal Swell at 60% on sync mode
  ReefAngel.PWM.SetActinic( millis()%1200<400?0:80); // Tidal Swell at 60% on anti-sync mode
  vtechmode=4;
  ReefAngel.PWM.SetDaylight( LongPulseMode(40,40,10,true) ); // Long pulse at 40% with 10s pulse on syncy mode
  ReefAngel.PWM.SetActinic( LongPulseMode(40,40,10,false) ); // Long pulse at 40% with 10s pulse on on anti-sync mode
    ReefAngel.PWM.SetActinic(0);
    ReefAngel.PWM.SetDaylight(0);
//Custom Main, Graph & Menu
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawDate(6, 4);
  ReefAngel.LCD.DrawLargeText(0,255,10,16,"  WP40 Mode:");
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,27,"Constant");
  else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,26,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,26,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,26,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,26,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,26,"Nutrient Trnsp.");
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,26,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,255,45,26,"Night");
  ReefAngel.LCD.DrawLargeText(0,255,17,49,"Sump");
  ReefAngel.LCD.DrawHugeText(COLOR_RED, 255, 12, 65, text, Num12x16);
  ReefAngel.LCD.DrawLargeText(0,255,100,40,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_BLUE, 255, 89, 55, text, Num8x8);
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,15,89, "WP40L");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,20,100, ReefAngel.PWM.GetDaylightValue());
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,88,89, "WP40R");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,95,100, ReefAngel.PWM.GetActinicValue());
  ReefAngel.LCD.DrawOutletBox(12, 113, TempRelay);
      if (WaveSync)
        return NewSpeed;
        return AntiSpeed;
Barry
Current tank info: 150g mixed reef
"Some of the worst mistakes of my life were hair cuts" -Jim Morrison
Re: Updated and trouble with code
what is not working and which error are you getting?
ReeferBee
Post by ReeferBee »
I got it figured out!
Barry
