rimai wrote:Did you use the correct cable?
The wifi and bluettoth cables are different.
BT cable has on extra wire that will carry the signal for reboot.
Make sure that 5 wire cable is connected between head unit and BT attachment.
Confirmed that I am using the correct cable. I am also getting a lot of crashes on the controller where the status light will go red, the screen will go black, and the unit would be unresponsive.
This is what I'm getting:
Using Port : \\.\COM7
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Recv:
avrdude done. Thank you.
