2 koralias
Rodasphoto
2 koralias
Post by Rodasphoto »
I used the wizard and programmed them both as random wave makers but one only get switched on. Is there a limitation on how many power heads I can set to wave maker? If there is what do I do with the second one to make it come on randomly?
Re: 2 koralias
Can you post your code?
Rodasphoto
Re: 2 koralias
    ReefAngel.FeedingModePorts = Port5Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
    ReefAngel.StandardLights( Port2,9,0,21,5 );
    ReefAngel.StandardLights( Port3,9,0,21,30 );
    ReefAngel.StandardLights( Port4,9,0,21,30 );
    ReefAngel.WavemakerRandom( Port5,60,100 );
    ReefAngel.WavemakerRandom( Port6,60,100 );
    ReefAngel.StandardHeater( Port7,778,784 );
    ReefAngel.PWM.SetChannel( 0, PWMParabola(9,0,20,0,15,100,15) );
    ReefAngel.PWM.SetChannel( 1, PWMParabola(8,30,20,30,15,100,15) );
    ReefAngel.Portal( "Rodasphoto" );
    int x,y;
    // Dimming Expansion
    x = 15;
    y = 2;
    for ( int a=0;a<6;a++ )
      if ( a>2 ) x = 75;
      if ( a==3 ) y = 2;
      y += 10;
Re: 2 koralias
Try this instead:
    ReefAngel.WavemakerRandom1( Port5,60,100 );
    ReefAngel.WavemakerRandom2( Port6,60,100 );
Rodasphoto
Re: 2 koralias
That seems to work. Weird because I used the wizard I used the wizard and thought it would do this automatically. Thanks for the help.
Bruz4023
Re: 2 koralias
Post by Bruz4023 »
i know this is old and dead but i want to revive it temporarily!
I have 2 koralias and i was wondering if you are just switching them on and off with the relays, or do you have fancier ones you can control the speed of? I just ordered so i havent played with anything yet!
The reason i ask is dont they reverse their direction often? Or just click loudly?
Re: 2 koralias
Only on and off. Direction reversing is a hit or miss issue from what I've heard
Re: 2 koralias
Mine spins backwards all the time.
One of them is even dead and inside the tank with its power plug disconnected :(
Worse is that I have 2x WP-25 (controllable Jebao pumps) brand new in the box waiting to be hooked up and I'm too lazy and out of time to do it... :oops:
Re: 2 koralias
rimai wrote:Mine spins backwards all the time.
yeah, mine would get screwed up too.
oh and I have a wp-40 that im too lazy to hook up as well. I feel your pain.
Sent from my Nexus 7
johniii
Re: 2 koralias
Post by johniii »
If your koralias spin backwards email hydor they will send you the stuff to fix it plus extra parts. They don't even ask the age.
Sent from my XT912 using Tapatalk 4
Bruz4023
Re: 2 koralias
Post by Bruz4023 »
ok because that is what mine do too!
hey if you to lazy to hook up that wp-40 i could take it off your hands i have been looking for one! probably one or two wp-25s would be better for my tank
Re: 2 koralias
Bruz4023 wrote:ok because that is what mine do too!
i plan on setting it up next week. that's one of my tasks for my vacation. :)
Rodasphoto
Re: 2 koralias
When I purchased mine they were the updated ones and do not spin backwards. I really have to listen carefully to hear that they come on.
