Float switches in parallel
CASPAR
Re: Float switches in parallel
Ok just tried code, changed time on controller to tomorrow at 12:59 pm box1_port5 came on at exactly 1pm ran for 2 minutes and box1_port6 has yet to come on......any ideas?
Yes the code sacohen gave for the second pump is way incorrect...
The -1200 should be -120
The %219600 i think thats what it was should be the same as the first pump...
Sorry doing this on the phone.
Can you try making the change and posting the two lines for me to check?
Also the <1200 in the second line should also be <120
I think hard to check post and i'll be able to scrutinize
CASPAR
// Box1_Port5 comes on first
ReefAngel.Relay.Set(Box1_Port5,(now()-3600)%129600<120); // Runs for 120s every 36 Hours
// Box1_Port6 comes on second
ReefAngel.Relay.Set(Box1_Port6,((now()-3600)-120)%121900<120); // Runs for 120s every 36 Hours with 120s offset
Also check my attached .ino would like to know if I can disable port3 on main box for say 10-15 after controller has initiated water exchange through box1_port 5&6
- Sacohen
Sorry I got the 2nd port real wrong.lnevo wrote:Yes the code sacohen gave for the second pump is way incorrect...
It should be
ReefAngel.Relay.Set(Box1_Port6,((now()-3600)-120)%129600<120); // Runs for 120s every 36 Hours with 120s offsetI'm really not sure how to do that.
CASPAR
Ok changed this part of code and port 6 is still not coming on......
// Water Exchange Routine
int Box1_Port5_Offset=3600;
int Box1_Port5_Runtime=129600;
int Box1_Port6_Offset=120;
int Box1_Port6_Runtime=120;
CASPAR
ok got it working here is what I did........
int Box1_Port6_Runtime=129600;
now if I only want it to run for say 1minute would I just change the 120's to 60?
- Sacohen
