Hi,
Is there a way to tell if my RA is running the latest Libraries? It's only a couple months old.
I'm having a problem where the screen becomes unresponsive. I can't say how often this occurs as I rarely touch it. But it seems every time I do, I have to reboot the RA to get the screen back.
Yesterday was an example.. I wanted to Calibrate my PH Probe and I had to reboot.
Anyway.. I want to make sure I'm using the latest software.
Rob
What Libraries am I using
Re: What Libraries am I using
The library version shoudln't cause that issue. But I believe you can get it within the Arduiono software and if you are using the standard menu on the RA, then there may be a Menu item when you click the joystick to show the version.
goisles1
Thanks Lee... That Worked.. Version 1.09
I'll give it a couple days and check it again.. I'm using the Android app anyway.. so I basically never even look at the screen and the app seems to work fine.
If it continues.. I'll post it as an issue.
- Contact:
from the Android app, if you select the Commands option from the menu, you will be presented with the ability to get the version from the controller thus keeping you from having to look at the screen.
just thought I'd point that out.
Sent from my Nexus 7
