Alternating Jebao
Mike S
Alternating Jebao
Post by Mike S »
I have two WP40's on my 300 and have another two WP60's on their way. Right now I'm just powering them through the relays and not controlling them with the dimming module. I'll probably do that in a few months, but in the meantime I plan on putting them on the sides of the tank facing each corner. The two WP40's will be in the back facing each other and the WP60's will be in the front facing each other. I'd like to run one combination of a WP40 and WP60 in opposite corners for a period of time to get a gyre flow going and then switch to the other pumps after a period of time to reverse the flow.
I could probably just use the lighting schedule to run one pair of pumps and the opposite function to reverse this, but instead I was thinking about going with a 6.5 hour schedule to simulate a normal tide schedule. I'm hoping that there is a way to turn a set of relays on for 6.5 and then off for 6.5 hours. The second set of pumps would run opposite this. Is this possible?
Mike
Re: Alternating Jebao
If I understand you correctly I think this post is similar to what you want to do (except 6 hr instead of 6.5 hrs)
http://forum.reefangel.com/viewtopic.php?f=12&t=4012
The 3rd from the bottom post is some code by lnevo that may be what you are looking for.
You would just need to change 12 hours to 13 hours and then cut that in half for the second part to 6.5*SECS_PER_HOUR
Mike S
Post by Mike S »
Thanks guys I'll give that a shot when my pumps come in.
