I guys,
I have some trouble with my RA and the client.
I wonder to retrive the memory data to change some parameters.
Anyway if I try to retrive them I am returned with the following error
"unable to retive controll memory settings. Refer to error log for more details"
Looking at the log file I found the following:
*****23/11/2013 16.34.17*****
Message:
Value cannot be null.
Parameter name: String
StackTrace:
at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info)
at ReefAngelClient.Form1.DisplayMemoryValues()
Can anybody help me?
As additional information I can say that I am not able to read and set the controllor date and time as well
Regards
Trouble with RA client
Re: Trouble with RA client
http://forum.reefangel.com/viewtopic.php?f=8&t=2103
Did you look at this thread?
Especially the last couple posts. There is a new ini file that needs to be applied.
steve
[quote=
Especially the last couple posts. There is a new ini file that needs to be applied.[/quote]
Thanks for the suggestion. Anyway I have loaded the ram ini file, but nothing is changed.
Any other suggestions
Make sure it is the same ini file as your libraries version.
Also, just to be sure, load the InitialInternalMemory code in the example codes folder and then load your code again.
steve
Doyou mean that I have to rebuild the code using the last updated library. Please note that I have uploaded it about two years ago...rimai wrote:Make sure it is the same ini file as your libraries version.
Ohh...
What is the version you have in the controller?
Click joystick and go to menu Version.
