Sketch Too Big
Squishie89
Sketch Too Big
Post by Squishie89 »
It is just not my day when it comes to the reef angel.
I have tried to reload the programing code, but I keep getting that the sketch is too big. I tried to downgrade the libraries all the way back to 1.0.0 and I still get that it is too big. It is at 31,978 on a regular RA head unit. Here is coding.
    ReefAngel.FeedingModePorts = Port3Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port5 );
    ReefAngel.StandardLights( Port1,13,30,22,30 ); //set for actinic
    ReefAngel.SingleATO( false,Port2,900,0 ); //15 min time out
    ReefAngel.StandardLights( Port4,14,0,22,0 ); //set for white light
    //removed wavemaker functions because I don't want them turning off
    ReefAngel.StandardHeater( Port7,775,780 );
    ReefAngel.PWM.SetDaylight( PWMSlope(13,30,22,0,15,100,30,15) );
    //ReefAngel.PWM.SetActinic( PWMParabola(13,0,22,30,15,100,15) );
    // prevent auto top off from 2200 to 1200
    if (hour()>12 && hour()<22)
      ReefAngel.SingleATO( false,Port2,600,0 );
      ReefAngel.Relay.Off( Port2 );
// Skimmer delay after feed or wc, 60 minutes
     ReefAngel.Relay.DelayedOn( Port3,60 );
    ReefAngel.Portal( "Squishie89" );
    int x,y;
    // Salinity
    // pH Expansion
    ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,75, "PHE:" );
    ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,39,75, ReefAngel.Params.PHExp );
    // Water Level
    ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,75, "WL:" );
    ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,75, ReefAngel.WaterLevel.GetLevel() );
    ReefAngel.LCD.DrawOutletBox( 12, 95, TempRelay );
Re: Sketch Too Big
You could try getting rid of the custom screen to see if that helps. Otherwise I'd need Roberto to chime in. The only thing I see that might throw you over is the Water Level sensor..
