ATO code ?
ATO code ?
I am looking for a simple code for my ato
Re: ATO code ?
Did you try to use the Wizard?
Which ATO port do you want to use?
Which relay port is the pump connected to?
Re: ATO code ?
I want to use just low with port 4
Re: ATO code ?
Use this:
ReefAngel.SingleATO(true,Port4,60,0); // ATO Low port with 60 seconds timeout
Re: ATO code ?
I'm looking for something similar, I already have a tsunami ATO so when water level is low it turn my pump on wich is on port 4 so I just want to know how can I setup my high level for protection just I case the Tzunami fail the RA ATO valve turn off the pump... I used the wizard and test it but the pump keeps on... Should I have an extra code? piece of equipment, level sensor?..
Re: ATO code ?
rimai wrote:Is your ATO a self contained ATO with its own float switches?
Yes it works pretty good i just want to use the RA float switch as a backup for hight level, just in case mine fail basically ti works with air pressure in a tub so when the water level is low the pressure release the feed water and as it get fill the pressure air increase and turn the pump off even though it has been working very well i want to add a backup plan
Re: ATO code ?
You can use something like this:
ReefAngel.Relay.Set(Port1,ReefAngel.HightATO.IsActive()); // Turns Port1 when the HighATO float switch isn't floating
Re: ATO code ?
rimai wrote:You can use something like this:Code: Select all
Awesome thanks a lot, I think I'm ready to order my wifi attachment, so excited about that option ...
Re: ATO code ?
Should i add something else like #include <HightATO> ? cause i'm having this error:
error: 'class ReefAngelClass' has no member named 'HightATO'
Re: ATO code ?
rimai wrote:Typo...
Should be HighATO instead of HightATO
LOL it's funny how a little thing can mess-up things...
BTW thanks Roberto i think this is the best customer service i ever had...
