Limmit which screen text is displayed on
paulvisco
Post by paulvisco »
Ok next question, Im using the new screen layout and wanted to put a large text of the temp1 in the extra space provided the below code does that for me but the problem is it is drwn over the splash screen and any sub menus.
Is there a way to get it to display on just the home screen..
#include <ReefAngel_Colors.h>
/////// Place global variable code below here
  ReefAngel.AddStandardMenu();
  ReefAngel.Use2014Screen();
  ReefAngel.AddDateTimeMenu();
  ReefAngel.FeedingModePorts = Port3Bit | Port7Bit | Port8Bit;
  ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
  ReefAngel.LightsOnPorts = Port4Bit | Port5Bit;
  ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit | Port5Bit | Port6Bit;
  ReefAngel.Relay.On( Port7 );
  ReefAngel.CustomLabels[0]="ATO";
  ReefAngel.CustomLabels[1]="Heater";
  ReefAngel.CustomLabels[2]="FAN";
  ReefAngel.CustomLabels[3]="Kessil";
  ReefAngel.CustomLabels[4]="LED";
  ReefAngel.CustomLabels[5]="Refugium";
  ReefAngel.CustomLabels[6]="F Pump";
  ReefAngel.CustomLabels[7]="C Pump";
  ReefAngel.StandardATO( Port1 );
  ReefAngel.StandardHeater( Port2 );
  ReefAngel.StandardFan( Port3 );
  ReefAngel.DayLights( Port4 );
  ReefAngel.ActinicLights( Port5 );
  ReefAngel.MoonLights( Port6 );
  ReefAngel.Relay.Set(Port5, !ReefAngel.Relay.Status(Port4));
  char text[7];
  byte TempColor = COLOR_GREEN;
  int TempLow = InternalMemory.HeaterTempOn_read();//789
  int TempHigh = InternalMemory.HeaterTempOff_read();//797
  if(ReefAngel.Params.Temp[T1_PROBE] < TempLow){TempColor = COLOR_BLUE;}
  if((ReefAngel.Params.Temp[T1_PROBE] >= TempLow)&&(ReefAngel.Params.Temp[T1_PROBE] <= TempHigh)){TempColor = COLOR_GREEN;}
  if(ReefAngel.Params.Temp[T1_PROBE] > TempHigh){TempColor = COLOR_RED;}
  ReefAngel.LCD.DrawHugeNumbers(TempColor, COLOR_WHITE, 30, 70, text);
  ReefAngel.Portal( "xxxxxx" );
Re: Limmit which screen text is displayed on
Try this:
if (MenuItem_2014==PARAMS_2014)
//Draw what you want here
paulvisco
Post by paulvisco »
PaulRA.cpp: In function 'void loop()':
PaulRA:91: error: 'MenuItem_2014' was not declared in this scope
PaulRA:91: error: 'PARAMS_2014' was not declared in this scope
Humm... the declaration is not global....
I don't know if this will work...
Try this:
  if (ReefAngel.MenuItem_2014==0)
paulvisco
Post by paulvisco »
Seems to not have an effect.. it still diplays on the reefangle splash screen and on the main screen and on the sub menu screen when you push the joystick down.. Humm...
but it does not error
paulvisco
Post by paulvisco »
I had it display the Value and it always stays zero..
paulvisco
Post by paulvisco »
Ok I get that test now it is referencing the screen number. so the code does keep it to just screen 0 but the next problem is that the splash screen is screen zero and the sub menu is still the screen number of the parent screen.
so when I press the joystick the temp is still displayed on the submenu text.
do the sub menus have a reference as well
so I would need to know if the splash screen has a way to tell if it is current (before the main display page is drawn)
and the sub menu text is on the screen.
Let's try another one
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && ReefAngel.MenuItem_2014==0)
paulvisco
Post by paulvisco »
Bingo!.. That did the trick...
Thanks much
paulvisco
Post by paulvisco »
Crude. any way to tell is the RA splash screen is being displayed just before the main display page is shown..
Try this:
if (ReefAngel.Splash)
// Do something
paulvisco
Post by paulvisco »
So this is what I came up with as a finalized snipit.
this will display temp1 on the home display screen in blue if under temp low green if between temp low and temp high and red if over temp high
Im happy might be a way to compact the sode a bit but this is working now
if (!ReefAngel.Splash)
    char text[7];
    byte TempColor;
    int TempON = InternalMemory.HeaterTempOn_read();//780
    int TempOFF = InternalMemory.HeaterTempOff_read();// 797
    if(ReefAngel.Params.Temp[T1_PROBE] < TempON){
    if((ReefAngel.Params.Temp[T1_PROBE] >= TempON)&&(ReefAngel.Params.Temp[T1_PROBE] <= TempOFF)){
    if(ReefAngel.Params.Temp[T1_PROBE] > TempOFF){
paulvisco
Post by paulvisco »
Also the PH display is still leaving screen droppings. if the PH displays XX.XX and then displays X.XX after the last printed number it leaves a bit of the 5 chr displayed..
