paulvisco
Posts: 53 Joined: Fri May 17, 2013 2:27 am
Post
by paulvisco » Fri Apr 11, 2014 11:43 pm
Ok next question, Im using the new screen layout and wanted to put a large text of the temp1 in the extra space provided the below code does that for me but the problem is it is drwn over the splash screen and any sub menus.
Is there a way to get it to display on just the home screen..
#include <ReefAngel_Colors.h>
/////// Place global variable code below here
ReefAngel.AddStandardMenu();
ReefAngel.Use2014Screen();
ReefAngel.AddDateTimeMenu();
ReefAngel.FeedingModePorts = Port3Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port4Bit | Port5Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.Relay.On( Port7 );
ReefAngel.CustomLabels[0]="ATO";
ReefAngel.CustomLabels[1]="Heater";
ReefAngel.CustomLabels[2]="FAN";
ReefAngel.CustomLabels[3]="Kessil";
ReefAngel.CustomLabels[4]="LED";
ReefAngel.CustomLabels[5]="Refugium";
ReefAngel.CustomLabels[6]="F Pump";
ReefAngel.CustomLabels[7]="C Pump";
ReefAngel.StandardATO( Port1 );
ReefAngel.StandardHeater( Port2 );
ReefAngel.StandardFan( Port3 );
ReefAngel.DayLights( Port4 );
ReefAngel.ActinicLights( Port5 );
ReefAngel.MoonLights( Port6 );
ReefAngel.Relay.Set(Port5, !ReefAngel.Relay.Status(Port4));
char text[7];
byte TempColor = COLOR_GREEN;
int TempLow = InternalMemory.HeaterTempOn_read();//789
int TempHigh = InternalMemory.HeaterTempOff_read();//797
if(ReefAngel.Params.Temp[T1_PROBE] < TempLow){TempColor = COLOR_BLUE;}
if((ReefAngel.Params.Temp[T1_PROBE] >= TempLow)&&(ReefAngel.Params.Temp[T1_PROBE] <= TempHigh)){TempColor = COLOR_GREEN;}
if(ReefAngel.Params.Temp[T1_PROBE] > TempHigh){TempColor = COLOR_RED;}
ReefAngel.LCD.DrawHugeNumbers(TempColor, COLOR_WHITE, 30, 70, text);
ReefAngel.Portal( "xxxxxx" );
Posts: 12857 Joined: Fri Mar 18, 2011 6:47 pm
Post
by rimai » Sat Apr 12, 2014 8:12 am
Try this:
if (MenuItem_2014==PARAMS_2014)
//Draw what you want here
paulvisco
Post
by paulvisco » Sat Apr 12, 2014 8:21 am
PaulRA.cpp: In function 'void loop()':
PaulRA:91: error: 'MenuItem_2014' was not declared in this scope
PaulRA:91: error: 'PARAMS_2014' was not declared in this scope
Post
by rimai » Sat Apr 12, 2014 8:32 am
Humm... the declaration is not global....
I don't know if this will work...
Try this:
paulvisco
Post
by paulvisco » Sat Apr 12, 2014 8:47 am
Seems to not have an effect.. it still diplays on the reefangle splash screen and on the main screen and on the sub menu screen when you push the joystick down.. Humm...
but it does not error
paulvisco
Post
by paulvisco » Sat Apr 12, 2014 8:51 am
I had it display the Value and it always stays zero..
paulvisco
Post
by paulvisco » Sat Apr 12, 2014 9:01 am
Ok I get that test now it is referencing the screen number. so the code does keep it to just screen 0 but the next problem is that the splash screen is screen zero and the sub menu is still the screen number of the parent screen.
so when I press the joystick the temp is still displayed on the submenu text.
do the sub menus have a reference as well
so I would need to know if the splash screen has a way to tell if it is current (before the main display page is drawn)
and the sub menu text is on the screen.
Post
by rimai » Sat Apr 12, 2014 9:06 am
Let's try another one
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && ReefAngel.MenuItem_2014==0)
paulvisco
Post
by paulvisco » Sat Apr 12, 2014 11:02 am
Bingo!.. That did the trick...
Thanks much
paulvisco
Post
by paulvisco » Sat Apr 12, 2014 12:22 pm
Crude. any way to tell is the RA splash screen is being displayed just before the main display page is shown..
Post
by rimai » Sat Apr 12, 2014 1:06 pm
Try this:
if (ReefAngel.Splash)
// Do something
paulvisco
Post
by paulvisco » Sat Apr 12, 2014 2:32 pm
So this is what I came up with as a finalized snipit.
this will display temp1 on the home display screen in blue if under temp low green if between temp low and temp high and red if over temp high
Im happy might be a way to compact the sode a bit but this is working now
if (!ReefAngel.Splash)
char text[7];
byte TempColor;
int TempON = InternalMemory.HeaterTempOn_read();//780
int TempOFF = InternalMemory.HeaterTempOff_read();// 797
if(ReefAngel.Params.Temp[T1_PROBE] < TempON){
if((ReefAngel.Params.Temp[T1_PROBE] >= TempON)&&(ReefAngel.Params.Temp[T1_PROBE] <= TempOFF)){
if(ReefAngel.Params.Temp[T1_PROBE] > TempOFF){
paulvisco
Post
by paulvisco » Sat Apr 12, 2014 2:50 pm
Also the PH display is still leaving screen droppings. if the PH displays XX.XX and then displays X.XX after the last printed number it leaves a bit of the 5 chr displayed..
