Error: 'class DCPumpClass' has no member named 'LowATOChann
Sebyte
Post by Sebyte »
I have just downloaded the 1.1.0. library and on compilation of my live code sketch I am getting the following erro: 'class DCPumpClass' has no member named 'LowATOChann
I am using the LowATO channel to control the DC pump and it has been working fine under 1.0.9. The code I have been using is shown below.
The question is, has the ReefAngel.DCPump.LowATOChannel function been changed in the latest software and any suggestion on how I can resolve the problem?
// *****************************JEBOA setup 16-09-13 *****************************
    ReefAngel.DCPump.FeedingSpeed=60;
    ReefAngel.DCPump.LowATOChannel=Sync;
Re: Error: 'class DCPumpClass' has no member named 'LowATOCh
Thought roberto incorporated that.. Did you download that from my git repo?
I don't think I got a pull request. Did I?
No idea. Probably not I guess. Can you pull the branch and get it merged??? All my git is based on 1.0.9 no idea how to bring it up to speed...
That and wifialert changes i'd like to push too...p.i.m.a.!!
Sebyte
Post by Sebyte »
I will stay on 1.0.9 for now. If you could incorporate the change I would be greatful.
Many thanks.
Sebyte
Post by Sebyte »
I did use the build from your git.
Do you have any idea when the next library build will be out and if the LowATOChann will be included.
Regards
I updated git for the new libs and pushed to roberto. You can download from mine again or wait till next release :)
Sebyte
Post by Sebyte »
Thank you Lee once again for your help.
Regards
oscarinw
Post by oscarinw »
Hey guys, any word on this?
I am on 1.1 and have my DC pump on the ATO port. I tried the
And now I'm getting the DCPump has no member compilation error. Is there a way to use wizard with the DC pump on the Low ATO with libraries at 1.1?
You can grab the Dev branch libraries from github. http://github.com/reefangel/Libraries
oscarinw
Post by oscarinw »
Sorry to be a pain. What should I do with which of these files?
You want to change the branch to dev and then on the bottom right you can download the zip file.
Unzip it and replace the libraries folder with whats inside
