Problem with Temperature Probe and Readings
djapel1
Post by djapel1 »
I have noticed that my controller is not reading temperature sometimes. I reuploaded the code last night and it was working and displaying the temperature but this morning it was back to showing 0.0. I plugged in the cable to upload the code and the controller reset and was displaying the temp again. I'm not sure what's going on.
djapel1
Re: Problem with Temperature Probe and Readings
Post by djapel1 »
I noticed last night when I was resetting it for the 4th time last night that it will display temp, then display 0.0, then the actual temp, and so on. Its like it is not getting a signal. Do I need to order a new one?
Do you only have 1 temp probe?
I'm currently having the same problem with one of my, but the strange thing is that Probe #3 was the one switching between error and the correct temp on the display, but after doing some trouble shooting it turned out to be Temp Probe #2 that had the problem.
djapel1
Post by djapel1 »
Yes I have just the one. Now I can't even upload anything... It keeps saying there was an error...
Unplug the temp probe, reboot and see if you can upload code then.
djapel1
Post by djapel1 »
Still not working. When I try to upload, the status light flashes three times and then I get the error. I checked the installer and it says that it timed out.
Make sure it says the correct com port.
Also check under tools and the correct board is checked as well as the correct com port.
djapel1
Post by djapel1 »
Ok. The Board is checked Reef Angel Plus Controller, Serial Port is COM3, and Programmer is AVRISP mkII
And when you start the arduino program is says Reef Angel is connected to COM3 in the lower right corner?
djapel1
Post by djapel1 »
Reef Angel Plus but yes.
Forgive me. I'm not in front on my computer right now so I'm trying to do it from memory.
I'm not sure what the problem could be.
You might want to consider uninstalling and re-installing the program
djapel1
Post by djapel1 »
I uninstalled the program and reinstalled and I still get the same timeout error.
I'm stumped.
djapel1
Post by djapel1 »
Me too. Good news is the temp is displaying again... But now a this new problem...
djapel1
Post by djapel1 »
Tuesday night I was able to upload just fine. All I did was name the ports and didn't change anything else.
djapel1
Post by djapel1 »
Yesterday I was able to upload and everything worked fine... The temperature was displaying and I wasn't getting an error. Then I decided to add the specific names for the ports into the code and now the temp won't display and I get the time out error. Could this be it?
It sounds like it could be.
Post your code and I'll take a look at it.
You may have accidentally left something out.
In the meantime go back to you old code if you can.
djapel1
Post by djapel1 »
Here is the entire code. Sorry if it is more than you need. I'll try and reset it to factory and redo the wizard without changing the names.
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit;
ReefAngel.CustomLabels[0]="ATO";
ReefAngel.CustomLabels[1]="Heater 1";
ReefAngel.CustomLabels[2]="Heater 2";
ReefAngel.CustomLabels[3]="Skimmer";
ReefAngel.CustomLabels[4]="Return";
ReefAngel.CustomLabels[5]="Powerhead 1";
ReefAngel.CustomLabels[6]="Powerhead 2";
ReefAngel.CustomLabels[7]="Not Used";
ReefAngel.SingleATO( true,Port1,240,0 );
ReefAngel.StandardHeater( Port2,765,770 );
ReefAngel.StandardHeater( Port3,751,761 );
ReefAngel.Relay.DelayedOn( Port4,10 );
ReefAngel.WavemakerRandom( Port6,30,45 );
ReefAngel.Relay.Set( Port7, !ReefAngel.Relay.Status( Port6 ) );
Ok. I though you were talking about defining the ports in the code so instead of saying Port1 in your code you can say ATO.
I see now that you are talking about custom labels for the display.
The main difference I see between your code and the example from this thread
http://forum.reefangel.com/viewtopic.ph ... els#p35470
ReefAngel.CustomLabels[0]="Heater";
ReefAngel.CustomLabels[1]="BlueLED";
ReefAngel.CustomLabels[2]="ReturnPump";
ReefAngel.CustomLabels[3]="WhiteLED";
ReefAngel.CustomLabels[4]="KalkATO";
ReefAngel.CustomLabels[5]="Moonlight";
ReefAngel.CustomLabels[6]="WP40";
ReefAngel.CustomLabels[7]="Refugium";
is that he does not have spaces in the name and you do.
ReefAngel.CustomLabels[1]="Heater1";
ReefAngel.CustomLabels[2]="Heater2";
ReefAngel.CustomLabels[5]="Powerhead1";
ReefAngel.CustomLabels[6]="Powerhead2";
ReefAngel.CustomLabels[7]="NotUsed";
or
ReefAngel.CustomLabels[1]="Heater_1";
ReefAngel.CustomLabels[2]="Heater_2";
ReefAngel.CustomLabels[5]="Powerhead_1";
ReefAngel.CustomLabels[6]="Powerhead_2";
ReefAngel.CustomLabels[7]="Not_Used";
