Single ATO
Christo
Single ATO
Post by Christo »
Hi Guys
If I want to use the SingleATO for the following!
The low-switch controls the sump level and the high-switch to act as a failsafe if the low-switch should get stuck at any time
Re: Single ATO
Try this:
ReefAngel.SingleATO(true,Port1,60,0);
if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port1);
Christo
Re: Single ATO
Post by Christo »
Thanx Roberto!
Christo
Re: Single ATO
Post by Christo »
Hi Guys! Still Strugling here!
Here is a PIC of how my floats are installed
So I want the lower one (ATOLow) to Control the level and the higher one (ATOHigh) for fail safe if something should happen to the Low switch
Re: Single ATO
photos are not showing :(
Christo
Re: Single ATO
Post by Christo »
Why?
Christo
Re: Single ATO
Post by Christo »
They are Installed next to each other! The one higher than the other! With the wires pointing upwards! Hope that makes sense!
Christo
Re: Single ATO
Post by Christo »
How about now?
Re: Single ATO
I think it has to do something with tapatalk :(
Christo
Re: Single ATO
Post by Christo »
Okay! But do you make sense of my description?
Re: Single ATO
Yes, but according to your description, the code posted above is what you need.
Christo
Re: Single ATO
Post by Christo »
It does not work! It works kinda viceversa! When the level is low the relay switches off, when high it switches on! The ATO also keeps Timming out!
Re: Single ATO
I think you have the float switches connected to the wrong ports.
Christo
Re: Single ATO
Post by Christo »
Its connected to the 2 Ports left of the pH probe!
Re: Single ATO
Yes, but I think they are inverted.
Christo
Re: Single ATO
Post by Christo »
Inverted? Meaning?
Re: Single ATO
ATO Low is on ATO High and ATO High is on ATO Low
Christo
Re: Single ATO
Post by Christo »
Nope! Checked that already!
Re: Single ATO
Then you probably have them upside down :) You can leave them mounted that way. Take the clip off and turn the float magnet upside down then put the clip back. That will reverse the behavior.
