Cloud and Lightning Code
Re: Cloud and Lightning Code
Yeah, this line is what sets the mode based on what's in the array...
if (chooseLightning) { lightningMode=LightningModes[random(100)%sizeof(LightningModes)]; chooseLightning=false; }
We'll have to do some logic here to set it to what's in InternalMemory... and how do you revert back to the random selections? We could do something like the PWM overrides, where if it's 255 we go back to our regularly scheduled program and if it's not then we hard code to that mode...
89delta wrote:Ok So I figured it out how to use the internal memory locations I think. Just not the actual location so am not sure just yet if it will mess with another setting.
But in Globals add:
#define Mem_B_StormMode 112
Then in checkcloud() find
static byte lightningMode=0; and replace with
static byte lightningMode=InternalMemory.read(Mem_B_StormMode);
Will be testing this right now.
Don't do this:
Instead, take this line out:
and replace with this:
lightningMode=InteralMemory.read(Mem_B_StormMode);
I think that should do it.
That does it but then we no longer have random cycling :)
lnevo wrote:That does it but then we no longer have random cycling :)
I thought that's what he wanted. :)
89delta
Post by 89delta »
Cool....you guys rock. Figured i'd take a shot at it Colin that way you're not overloaded...
89delta
Post by 89delta »
Oh don't get me wrong guys. Love the random part of it. But enjoying re-learning the code structure on how it all works and trying different things out. Besides the random part wouldn't work with slower drivers unless we can "over-ride" it by being able to select just the "Slow" Mode for the ELN's or other drivers. As the Fast and Mega modes work fine with the LDD's and the CAT4101's i've got laying around.
No problem!
Lee, how is it done with the DC pumps? Isn't there a way to cycle through them with memory control? I'm not up on them...
Yes, but we should strive to maintain a single code base :) I'm trying to avoid multiple versions.
With the DCPumps we have a variable UseMemory that we set when we want to use Memory or Override.
We can keep the line in there, but I recommend if Memory is 255 then go with the Array. If it's set than go with the mode that's set.
89, thats the nice thing about the array though, if you have slow drivers, just put Slow :) Random is useless (for now) with the slow drivers, until someone comes up with a second "slow" method :)
89delta
Post by 89delta »
lnevo wrote:Yes, but we should strive to maintain a single code base :) I'm trying to avoid multiple versions.
True Lee....But I was kinda of thinking along your wanting to turn this into another class and just being able to have the end user select which one to use. Nevermind....am having a brain fart. I get what you're saying now. After you get this into another class we just add the coding for it into our INO:
byte LightningModes[] = { Slow }; or
byte LightningModes[] = { Slow, Fast, Mega };
Yeah when we get to that point we can do something like we do for dcpump. I like how all this is proceeding. Ideas are great, keep em coming!
I've been working on some upgrades to the lightning engine. Stay tuned!
Update to OP
Improved lightning engine.
New option for increased Mega Lightning.
Cool, but by making the rate a define, we can't modify it on the fly through mem or variable changing. So, let's get away from using #defines for this... :) At some point I'll be making them all properties of the Cloud class.
My recommendation though would be to make it a separate mode... so Mega1 Mega2. This way we maintain one variable to choose which mode we want. Very cool updates though, keep em coming...
lnevo wrote:Cool, but by making the rate a define, we can't modify it on the fly through mem or variable changing. So, let's get away from using #defines for this... :) At some point I'll be making them all properties of the Cloud class.
Done. Went with Mega and Mega2, since Mega1 looks like Megal. :mrgreen:
Did you see that chalice encrusted on the Megaladon tooth? :)
New mode:
Calm
No lightning at all. Good for putting into a random sequence so there isn't lightning every time there is a cloud. OP updated.
jegillis
Post by jegillis »
Is there a version of this code for the dimming expansion?
No. I'm sure it could be adapted, but I don't have a dimming expansion. :(
RANet dimming expansion on the way! :D
Lee, have you done any work on putting this into a library? If not, I may start as a learning experience.
I haven't had time yet.. feel free to give it a try and I can certainly help :)
Awesome! I've always thought that the best way to learn something was to do it. I'm sure I'll have questions.
The lightning will have to be incorporated in the slave side. The cloud should be fine.
The RANet bandwidth is not fast enough.
It sends data every 100ms.
rimai wrote:The lightning will have to be incorporated in the slave side. The cloud should be fine.
Slave side? Esplain please.
Every RANet-Ready Wireless Module has a microcontroller in it to receive and process the wireless data.
The current firmware can only process data for relays and dimming channels.
We will need to create a firmware that can accept commands, so you can trigger remotely.
For example, a command to trigger the lightning effect on the dimming module.
You are not the only one that will want this.
The person using the dimmable LED driver wants this too.
I just need to find some time to put something together, but I'd like to release the next libs first.
The RANet requires some changes on the core libraries released from Arduino, specifically the SoftwareSerial library and I'd like to have at least the base communication working and released before we start adding functionality to it.
We have been getting some help from Sacohen, lnevo, AlanM, binder and others to see if any other minor bug is found.
Hopefully, we get a release soon.
I updated the previous post.
I meant to say RANet-Ready Wireless Module and not RANet-Add On.
Ah, I see. Load the sequence and then trigger when needed. I understand.
jegillis
Post by jegillis »
And I thought that just coding this for the dimming expansion would work. I don't know how to code much of anything but would be happy to test anything you come up with.
TheMikey
Post by TheMikey »
I feel like a bit of an idiot, but I can't seem to find this line:
To even start this programming. Is there an updated full code I need to find somewhere before attempting to customize this?
The updated code is in the first post.
Do a search for this:
 byte LightningModes[] = { Mega, Mega, Mega2, Calm, Calm };
And change it to your liking.
TheMikey
Post by TheMikey »
Found it! Thanks!
