Howaboutme's Code
howaboutme
Howaboutme's Code
Post by howaboutme »
For the record and so I can link to this on threads.
The below is for a now broken down tank:
            ReefAngel.FeedingModePorts = Port1Bit | Port5Bit;
            ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port6Bit | Port8Bit;
            ReefAngel.OverheatShutoffPorts = Port8Bit;
            ReefAngel.Relay.On( Port2 );
        ReefAngel.CustomLabels[0]="ATO Pump";
        ReefAngel.CustomLabels[1]="Skimmer";
        ReefAngel.CustomLabels[2]="LEDWhite";
        ReefAngel.CustomLabels[3]="LEDBlue";
        ReefAngel.CustomLabels[4]="WP25";
        ReefAngel.CustomLabels[5]="DoserAlk";
        ReefAngel.CustomLabels[6]="Unused";
        ReefAngel.CustomLabels[7]="Heater";
            ReefAngel.SingleATOLow( Port1 );
            ReefAngel.DayLights( Port3 );
            ReefAngel.ActinicLights( Port4 );
            ReefAngel.Relay.DelayedOn( Port5 );
            ReefAngel.DosingPumpRepeat1( Port6 );
            ReefAngel.StandardHeater( Port8 );
            if (ReefAngel.DCPump.Mode==Custom)
              if ( (now()%SECS_PER_DAY >= 77400) || (now()%SECS_PER_DAY<= 34200) )
                ReefAngel.PWM.SetActinic(32); // Constant at 32% on sync mode
              else if ( (now()%SECS_PER_DAY >= 34200) && (now()%SECS_PER_DAY<= 48600) )
                ReefAngel.PWM.SetActinic(36); // Constant at 36% on sync mode
              else if ( (now()%SECS_PER_DAY >= 48600) && (now()%SECS_PER_DAY<= 77400) )
                ReefAngel.PWM.SetActinic( ElseMode(41,8,true));   // Else on sync mode, 41 +/- 8%
            ////DoserAlk Schedule
              if ((hour() > 10) && (hour() < 22)) { // Between 10am and 10pm we will disable Port 6
              ReefAngel.Relay.Off(Port6);
            ////Water change delay for Port 1
          static time_t wcTimer;
          if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE) wcTimer=now();
          if (now()-wcTimer > 0 && now()-wcTimer < 600) {
          ReefAngel.Relay.Off(Port1);
          else {ReefAngel.SingleATOLow (Port1 );
            ReefAngel.Portal( "howaboutme" );
          static unsigned long LastChange=millis();        // Set the inital time that the last change occurred
          static int Delay = random( 500, 3000);           // Set the initial delay
          static int NewSpeed = MidPoint;                  // Set the initial speed
          static int AntiSpeed = MidPoint;                 // Set the initial anti sync speed
          if ((millis()-LastChange) > Delay)               // Check if the delay has elapsed
            Delay=random(500,5000);                        // If so, come up with a new delay
            int ChangeUp = random(Offset);                 // Amount to go up or down
            if (random(100)<50)                            // 50/50 chance of speed going up or going down
            LastChange=millis();                           // Reset the time of the last change
          if (WaveSync)
            return NewSpeed;
            return AntiSpeed;
Key Attributes
- Able to control pump settings via portal
- When in "custom mode": WP-25 is in else mode between 1:30pm and 9:30pm, constant mode at 32% between 9:30pm and 9:30am and 36% between 9:30am and 1:30pm.
- Doses Alk 12 times a day, once per hour between 10:00pm and 10:00am, controlled via portal
- Added ATO Low code to support my Avast ATO.
This one is for the current tank for record:
// Set to start at 9:45am and run for 10 minutes
    #define AUTO_SAL_START_HOUR     9
    #define AUTO_SAL_START_MINUTE   45
    #define AUTO_SAL_RUN_TIME       10
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port5Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port5Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port8Bit;
    // Salinity Temp Compensation
    ReefAngel.Salinity.SetCompensation(0);
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.Relay.On( Port5 );
        ReefAngel.CustomLabels[2]="Light";
        ReefAngel.CustomLabels[3]="Nero3";
        ReefAngel.CustomLabels[4]="Return Pump";
        ReefAngel.CustomLabels[5]="Unused";
    ReefAngel.StandardLights( Port2 ); // putting skimmer on timer
     // First 10 minutes after WC disable ATO for port 1
    // Compute the current time
    int CurrentTime = NumMins(hour(), minute());
    // Compute the starting time for the auto salinity calibration
    int AutoSalStartTime = NumMins(AUTO_SAL_START_HOUR, AUTO_SAL_START_MINUTE);
    // Compute the ending time for the auto salinity calibration by adding in the run time
    int AutoSalEndTime = AutoSalStartTime + AUTO_SAL_RUN_TIME;
    // Check if it's time to start the auto salinity calibration
    if (  AutoSalStartTime == CurrentTime ) {
      // Switch to Salinity Calibration ONLY if we are on the main / default menu
      // Don't switch to the calibration menu if we are doing something else (water change, feeding, etc)
      if ( (ReefAngel.DisplayedMenu == DEFAULT_MENU) || (ReefAngel.DisplayedMenu == MAIN_MENU) ) {
        ReefAngel.ChangeMode = SAL_CALIBRATE_MENU;
    // Check if we are at the end of the Run Time for the auto salinity calibration
    if ( AutoSalEndTime == CurrentTime ) {
      // Simulate a button press ONLY if we are still on the Salinity Calibration menu screen
      if (ReefAngel.DisplayedMenu == SAL_CALIBRATE_MENU) {
        ButtonPress++;
Key attributes:
- Water change pump delay
- Salinity temp compensation
- Put skimmer on timer by setting it to daylight and controlled via portal
- Auto calibrate salinity probe to compensate for having the skimmer on overnight
This one's for my new UNS 75s tank:
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port8Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port8Bit;
        ReefAngel.CustomLabels[2]="MP10 Left";
        ReefAngel.CustomLabels[3]="MP 10 Right";
        ReefAngel.CustomLabels[5]="Doser Alk";
        ReefAngel.CustomLabels[7]="Inkbird";
    ReefAngel.Relay.DelayedOn(Port3 );
    ReefAngel.Relay.DelayedOn(Port4 );
     //DoserAlk Schedule
              ;if ((hour() > 10) && (hour() < 22)) { // Between 10am and 10pm we will disable Port 6
Key attributes:
Jack
Ridwaan
Re: Howaboutme's Code
Post by Ridwaan »
howaboutme wrote:For the record and so I can link to this on threads.
            ReefAngel.FeedingModePorts = Port5Bit;
            ReefAngel.WaterChangePorts = Port2Bit | Port5Bit | Port6Bit | Port8Bit;
        ReefAngel.CustomLabels[0]="Unused";
          if (WaveSync)
            return NewSpeed;
            return AntiSpeed;
Key Attributes
WOW, thanks
Ive got it now...
