So I haven't had a lot of time to work on this, but I think I have it doing most of what I want as far as the clouds go. My code is posted below. I do have a few concerns though. Is my code using 12-bit resolution for the dimming for light cycles as well as for clouds? When it is dimming for the clouds how quickly is it sending new data to the dimming expansion (once a second, minute, etc)?
Also, how would I be able to change the shortcloudduration to seconds instead of minutes?
int PWMChannel[16];
int DaylightPWMValue;
ReefAngel.Init();
//Initialize controller
ReefAngel.Use2014Screen();
// Let's use 2014 Screen
ReefAngel.AddPHExpansion();
// pH Expansion Module
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port1Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit;
ReefAngel.Relay.On( Port4 );
// Add support for 16 channel PWM board
ReefAngel.Add16ChPWM();
ReefAngel.SingleATO( true,Port1,90,0 );
ReefAngel.StandardHeater( Port2,820,825 );
ReefAngel.StandardHeater( Port3,815,823 );
ReefAngel.WavemakerRandom( Port5,25,45 );
ReefAngel.WavemakerRandom( Port6,25,45 );
ReefAngel.StandardLights( Port7,21,0,7,0 );
ReefAngel.CO2Control( Port8,670,675 );
ReefAngel.DosingPumpRepeat( Box1_Port1,0,60,10 );
//0 = White Far East
PWMChannel[0]=PWMParabola(8,0,20,30,0,80,0);
//1 = White Near East
PWMChannel[1]=PWMParabola(8,5,20,35,0,80,0);
//2 = White Near West
PWMChannel[2]=PWMParabola(8,10,20,40,0,80,0);
//3 = White Far West
PWMChannel[3]=PWMParabola(8,15,20,45,0,80,0);
//4 = Blue Far East
PWMChannel[4]=PWMParabola(7,15,21,15,0,80,0);
//5 = Blue Near East
PWMChannel[5]=PWMParabola(7,20,21,20,0,80,0);
//6 = Blue Near West
PWMChannel[6]=PWMParabola(7,25,21,25,0,80,0);
//7 = Blue Far West
PWMChannel[7]=PWMParabola(7,30,21,30,0,80,0);
//8 = OCW Far East
PWMChannel[8]=PWMParabola(8,15,20,15,0,60,0);
//9 = OCW Near East
PWMChannel[9]=PWMParabola(8,20,20,20,0,60,0);
//10 = OCW Near West
PWMChannel[10]=PWMParabola(8,25,20,25,0,60,0);
//11 = OCW Far West
PWMChannel[11]=PWMParabola(8,30,20,30,0,60,0);
//12 = Violets
PWMChannel[12]=PWMParabola(8,15,20,30,0,65,0);
//13 = Moonlight Far East
PWMChannel[13]=PWMParabola(20,15,8,30,0,15,0);
//14 = Moonlight Near East and West
PWMChannel[14]=PWMParabola(20,20,8,35,0,15,0);
//15 = Moonlight Far West
PWMChannel[15]=PWMParabola(20,25,8,40,0,15,0);
CheckCloud();
ReefAngel.PWM.Set16Channel(0,PWMChannel[0]);
ReefAngel.PWM.Set16Channel(1,PWMChannel[1]);
ReefAngel.PWM.Set16Channel(2,PWMChannel[2]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[3]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[4]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[5]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[6]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[7]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[8]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[9]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[10]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[11]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[12]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[13]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[14]);
ReefAngel.PWM.Set16Channel(3,PWMChannel[15]);
ReefAngel.AddWifi();
void CheckCloud()
#define Clouds_Every_X_Days 1
// Minimum number of minutes for long cloud duration. Don't use min duration of less than 6
#define Min_Cloud_Duration 7
// Maximum number of minutes for long cloud duration. Don't use max duration of more than 255
#define Max_Cloud_Duration 15
// Minimum number of minutes for short cloud duration.
#define Min_ShortCloud_Duration 1
// Maximum number of minutes for short cloud duration.
#define Max_ShortCloud_Duration 2
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 12
// Minimum number of short clouds that can happen per day
//#define Min_ShortClouds_per_Day 3
// Maximum number of short clouds that can happen per day
//#define Max_ShortClouds_per_day 10
// In this example, start could after 8:30am (in minutes since midnight)
#define Start_Cloud_After 510
// In this example, end could before 7:00pm (in minutes since midnight)
#define End_Cloud_Before 1140
// Percentage chance of a lightning happen for every long cloud
#define Lightning_Change_per_Cloud 80
// Channels used by the actinic LEDs on the PWM Expansion module
// These channels will not be dimmed when the cloud effect is triggered
// Number is a binary form. B001100 means channel 2 and 3 are used for actinics
// 0000111100000000
#define Actinic_Channels 384
// Channels used by the daylight LEDs on the PWM Expansion module
// These channels will be used for the spike when lightning effect is triggered
// Number is a binary form. B000011 means channel 0 and 1 are used for daylights
// 1111000000000000
#define Daylight_Channels 61440
// Add Random Lightning modes
#define Calm 0 // No lightning
#define Slow 1 // 5 seconds of slow lightning in the middle of a cloud for ELN style (slow response) drivers
#define Fast 2 // 5 seconds of fast lightning in the middle of a cloud for LDD style (fast response) drivers
#define Mega 3 // Lightning throughout the cloud, higher chance as it gets darker
#define Mega2 4 // Like Mega, but with more lightning
// Set which lightning modes you want to use
// Example: { Slow, Fast, Mega, Mega2 } to randomize all four modes.
// { Mega2 } for just Mega2. { Mega, Mega, Fast} for Mega and Fast, with twice the chance of Mega.
byte LightningModes[] = { Mega, Mega, Mega2, Calm, Calm, Fast };
// Add Random Cloud modes
#define FastEast 0 //Short cloud coming from the east - No Lightning
#define FastWest 1 //Short cloud coming from the west - No Lightning
#define SlowEast 2 //Long cloud coming from the east - Chance of Lightning
#define SlowWest 3 //Long cloud coming from the west - Chance of Lightning
// Set which cloud modes you want to use
//Example: {FastEast, FastWest, SlowEast, SlowWest } to randomize all four modes
byte CloudModes[] = { FastEast, FastWest, FastEast, FastWest, FastEast, FastWest, SlowEast, SlowWest };
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
static byte lightningMode=0;
static boolean chooseCloud=true;
static byte cloudMode=0;
static time_t DelayCounter=millis(); // Variable for lightning timing.
static int DelayTime=random(1000); // Variable for lightning timimg.
static time_t DelayCount=millis();
static int DelayTiming1=2000;
static int DelayTiming2=4000;
static int DelayTiming3=6000;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
randomSeed(millis()); // Seed the random number generator
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
// pick a random number for the short cloud duration
shortcloudduration=random(Min_ShortCloud_Duration,Max_ShortCloud_Duration);
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
if (chooseCloud)
cloudMode=CloudModes[random(100)%sizeof(CloudModes)];
chooseCloud=false;
switch (cloudMode)
case FastEast;
//dim down the far east channels
PWMChannel[0]=ReversePWMSlope(cloudstart,cloudstart+shortcloudduration,PWMChannel[0],0,20);
PWMChannel[8]=ReversePWMSlope(cloudstart,cloudstart+shortcloudduration,PWMChannel[8],0,20);
//dim down the near east channels
PWMChannel[1]=ReversePWMSlope(cloudstart+DelayTiming1,cloudstart+shortcloudduration+DelayTiming1,PWMChannel[1],0,20);
PWMChannel[9]=ReversePWMSlope(cloudstart+DelayTiming1,cloudstart+shortcloudduration+DelayTiming1,PWMChannel[9],0,20);
//dim down the near west channels
PWMChannel[2]=ReversePWMSlope(cloudstart+DelayTiming2,cloudstart+shortcloudduration+DelayTiming2,PWMChannel[2],0,20);
PWMChannel[10]=ReversePWMSlope(cloudstartDelayTiming2,cloudstart+shortcloudduration+DelayTiming2,PWMChannel[10],0,20);
//dim down the far west channels
PWMChannel[3]=ReversePWMSlope(cloudstart+DelayTiming3,cloudstart+shortcloudduration+DelayTiming3,PWMChannel[3],0,20);
PWMChannel[11]=ReversePWMSlope(cloudstart+DelayTiming3,cloudstart+shortcloudduration+DelayTiming3,PWMChannel[11],0,20);
chooseLightning=false;
break;
case FastWest;
PWMChannel[3]=ReversePWMSlope(cloudstart,cloudstart+shortcloudduration,PWMChannel[3],0,20);
PWMChannel[11]=ReversePWMSlope(cloudstart,cloudstart+shortcloudduration,PWMChannel[11],0,20);
PWMChannel[2]=ReversePWMSlope(cloudstart+DelayTiming1,cloudstart+shortcloudduration+DelayTiming1,PWMChannel[2],0,20);
PWMChannel[10]=ReversePWMSlope(cloudstart+DelayTiming1,cloudstart+shortcloudduration+DelayTiming1,PWMChannel[10],0,20);
PWMChannel[1]=ReversePWMSlope(cloudstart+DelayTiming2,cloudstart+shortcloudduration+DelayTiming2,PWMChannel[1],0,20);
PWMChannel[9]=ReversePWMSlope(cloudstart+DelayTiming2,cloudstart+shortcloudduration+DelayTiming2,PWMChannel[9],0,20);
PWMChannel[0]=ReversePWMSlope(cloudstart+DelayTiming3,cloudstart+shortcloudduration+DelayTiming3,PWMChannel[0],0,20);
PWMChannel[8]=ReversePWMSlope(cloudstart+DelayTiming3,cloudstart+shortcloudduration+DelayTiming3,PWMChannel[8],0,20);
break;
case SlowEast;
PWMChannel[0]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[0],0,180);
PWMChannel[8]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[8],0,180);
PWMChannel[1]=ReversePWMSlope(cloudstart+DelayTiming1,cloudstart+cloudduration+DelayTiming1,PWMChannel[1],0,180);
PWMChannel[9]=ReversePWMSlope(cloudstart+DelayTIming1,cloudstart+cloudduration+DelayTiming1,PWMChannel[9],0,180);
PWMChannel[2]=ReversePWMSlope(cloudstart+DelayTiming2,cloudstart+cloudduration+DelayTiming2,PWMChannel[2],0,180);
PWMChannel[10]=ReversePWMSlope(cloudstart+DelayTiming2,cloudstart+cloudduration+DelayTiming2,PWMChannel[10],0,180);
PWMChannel[3]=ReversePWMSlope(cloudstart+DelayTiming3,cloudstart+cloudduration+DelayTiming3,PWMChannel[3],0,180);
PWMChannel[11]=ReversePWMSlope(cloudstart+DelayTiming3,cloudstart+cloudduration+DelayTiming3,PWMChannel[11],0,180);
break;
case SlowWest;
PWMChannel[3]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[3],0,180);
PWMChannel[11]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,PWMChannel[11],0,180);
PWMChannel[2]=ReversePWMSlope(cloudstart+DelayTiming1,cloudstart+cloudduration+DelayTiming1,PWMChannel[2],0,180);
PWMChannel[10]=ReversePWMSlope(cloudstart+DelayTiming1,cloudstart+cloudduration+DelayTiming1,PWMChannel[10],0,180);
PWMChannel[1]=ReversePWMSlope(cloudstart+DelayTiming2,cloudstart+cloudduration+DelayTiming2,PWMChannel[1],0,180);
PWMChannel[9]=ReversePWMSlope(cloudstart+DelayTiming2,cloudstart+cloudduration+DelayTiming2,PWMChannel[9],0,180);
PWMChannel[0]=ReversePWMSlope(cloudstart+DelayTiming3,cloudstart+cloudduration+DelayTiming3,PWMChannel[0],0,180);
PWMChannel[8]=ReversePWMSlope(cloudstart+DelayTiming3,cloudstart+cloudduration+DelayTiming3,PWMChannel[8],0,180);
break;
chooseCloud=true; // Reset the flag to choose a new cloud type
int newdata=4095;
byte channel=0;
if (chooseLightning)
switch (lightningMode)
case Calm:
break;
case Mega:
// Lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
int a=random(1,5); // Pick a number of consecutive flashes from 1 to 4.
for (int i=0; i<a; i++)
for (int g=0;g<16;g++)
if (bitRead(Daylight_Channels,g)==1)
newdata=random(DaylightPWMValue*40.95, 4095);
channel=g;
Wire.beginTransmission(0x41);
Wire.write(0x8+(4*channel));
Wire.write(newdata&0xff);
Wire.write(newdata>>8);
Wire.endTransmission();
int randy=random(20,80); // Random number for a delay
if (randy>71) randy=((randy-70)/2)*100; // Small chance of a longer delay
delay(randy); // Wait from 20 to 69 ms, or 100-400 ms
for (int h=0;h<16;h++)
if (bitRead(Daylight_Channels,h)==1)
newdata=DaylightPWMValue*40.95;
channel=h;
delay(random(30,50)); // Wait from 30 to 49 ms
wdt_reset();
DelayCounter=millis(); // If we just had a round of flashes, then lets put in a longer delay
DelayTime=random(1000); // of up to a second for dramatic effect before we do another round.
break;
case Mega2:
// Higher lightning chance from beginning of cloud through the end. Chance increases with darkness of cloud.
if (lightningchance && random(ReversePWMSlope(cloudstart,cloudstart+cloudduration,100,0,180))<2 && (millis()-DelayCounter)>DelayTime)
for (int k=0;k<16;k++)
if (bitRead(Daylight_Channels,k)==1)
channel=k;
for (int l=0;l<16;l++)
if (bitRead(Daylight_Channels,l)==1)
channel=l;
wdt_reset();
break;
case Fast:
for (int e=0;e<16;e++)
if (bitRead(Daylight_Channels,e)==1)
channel=e;
for (int f=0;f<16;f++)
if (bitRead(Daylight_Channels,f)==1)
channel=f;
wdt_reset();
break;
case Slow:
// Slow lightning for 5 seconds in the middle of the cloud. Suitable for slower ELN style drivers
else lightningstatus=0;
if (lightningstatus)
newdata=4095;
for (int c=0;c<16;c++)
if (bitRead(Daylight_Channels,c)==1)
channel=c;
newdata=0;
for (int d=0;d<16;d++)
if (bitRead(Daylight_Channels,d)==1)
channel=d;
delay(1);
break;
default:
break;
cloudindex++;
if (cloudindex < numclouds)
// Write the times of the next cloud, next lightning, and cloud duration to the screen.
int x=0;
else x=17;
else x=35;
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51;
else x=57;
if (((cloudstart+(cloudduration/2))%60)>=10) x=69;
else x=75;
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
