couple issues
couple issues
I just purchased the wifi for my reef angel. Every since I've been having some issues with the controler not keeping the program. My light dont turn on when they are suppose to. It is set for 11am to 8pm but they just dont turn on at all.
Re: couple issues
Yes the time is correct. I'm a noob how do you post the code?
Re: couple issues
Open the sketch and copy it, then go to the Full Editor mode on here and there is a button at the top that says code.
Once you get the "" place the code from you sketch in between the 2 codes.
Once you get the "
Re: couple issues
I figured out the problem. I thought on the android app when the green oval is on that means it set for automatic mode. Once I turned them all off it started working again.
Re: couple issues
Good.
Then green oval is showing that it is in an override state.
If it's supposed to be off then it is overrided to on and visa-versa.
