Main Relay
1. Skimmer
2. LED fan
3. LED power supply 1
4. LED power supply 2
5. RW8
6. MJ1200 water mixing station
7. Heater
8. DC3000
Expansion Relay 1
1. ATO
2. Not Used
3. Not Used
4. Not Used
5. Autowater change 1
6. Autowater change 2
7. Not Used
8. Not Used
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port1Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port4Bit | Port7Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port8Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port7Bit;
ReefAngel.DayLights( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.DayLights( Port4 );
ReefAngel.DayLights( Port5 );
ReefAngel.DosingPumpRepeat1( Port6 );
ReefAngel.DayLights( Box1_Port1 );
ReefAngel.PWM.Channel0PWMParabola();
ReefAngel.PWM.Channel1PWMParabola();
ReefAngel.PWM.Channel2PWMParabola();
ReefAngel.PWM.Channel3PWMParabola();
ReefAngel.PWM.Channel4PWMParabola();
ReefAngel.PWM.Channel5PWMParabola();
ReefAngel.Relay.On( Box1_Port1 ); // ATO port is always on
ReefAngel.DosingPumpRepeat1(Box1_Port6); // AWC change 2 (add)
ReefAngel.DosingPumpRepeat2(Box1_Port5); // AWC change 1 (drain)
ReefAngel.Portal( "Rodasphoto" );
