IOs 9 - Dimming Override -> Stuck
joaocdestro
Post by joaocdestro »
When I try to override some values in Dimm expantion in the RF Iphone APP it get stuck, freeze the app.
Regards,
Joao C. Destro
Re: IOs 9 - Dimming Override -> Stuck
Was it working before on a previous version OS or you never tried it with a different OS?
Christo
Post by Christo »
IOS 9 Is heavily flawed!!!! Causes a lot of apps to crash.
It worked ok for me but the app crashed a few times and it seems a little choppy, same for changing the RF.
joaocdestro
app in IOS 8 OK
https://youtu.be/awafimv3OIA
app in IOS 9 stuck after dimm change
https://youtu.be/HxrTwY6uUgU
Regards,
Joao C. Destro
joaocdestro
rimai wrote:Was it working before on a previous version OS or you never tried it with a different OS?
app in IOS 8 OK
Regards,
Joao C. Destro
JoelIreland
Post by JoelIreland »
Having same issue with it crashing on iPhone 6 with iOS9 ( it wont adjust dimming ) but on iPad air with iOS 9 it adjusts the dimming and freezes.
This is becoming more of an issue. Tried setting the dim yesterday and it kept crashing me out of the app.
skehole
Post by skehole »
I don't use the uapp for dimming, but it won't let me into the setting on my controller anymore. It just defaults back to the home screen
fckgravity
Post by fckgravity »
I am getting the same issues as all of the above. with a 6s and ios 9.0.2
Civics14
Post by Civics14 »
Same issue here - any possibility of updating the app to be compatible with ios 9?
It's in the works.
Unfortunately, the iOS9 broke core functionality and the entire app has to be redesigned.
rimai wrote:It's in the works.
yuck. stupid ios....doing it again to us like they did with 7 (i think).
It doesn't seem that broken. Out of curiosity what did they change that requires such a big redesign?
We use jquery and jquery ui as our user interface framework and it doesn't work well on ios9.
So, I'm changing it to angularjs
