Spotted
Posts: 100 Joined: Thu May 10, 2012 5:46 am
Post
by Spotted » Tue Sep 29, 2015 4:03 pm
I am moving my programming to the internal memory. I would like to set up different scheduled times for certain lights and power heads.
Is it possible to have 2 different scheduled times? I have been using the Wizard, but it only allows for 1 time for what it calls the light schedule.
I want to shut off my power heads at 10 PM and turn on turf scrubber LEDs at 6 PM, also I want them both to turn back on at different times as well.
Is this possible?
I also want one more thing. Is it possible to turn on Nutrient Mode for my Jebao power heads once Feeding Mode has ended?
ReefAngel.FeedingModePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.FeedingModePortsE[0] = Port3Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePortsE[0] = Port3Bit;
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.DayLights( Port5 );
ReefAngel.StandardHeater( Port6 );
ReefAngel.Relay.DelayedOn( Port7 );
ReefAngel.Relay.DelayedOn( Port8 );
ReefAngel.DosingPumpRepeat1( Box1_Port3 );
if ((now()%SECS_PER_DAY==31320)) //if it is 8:42 AM
{ReefAngel.FeedingModeStart();} //START FEEDING MODE
if ((now()%SECS_PER_DAY==67320)) //if it is 6:42 PM
ReefAngel.Portal( "spotted" );
Spotted
Post
by Spotted » Tue Sep 29, 2015 5:47 pm
Can I do a mix of standard lights in the memory locations and manually code in the other times?
Posts: 12857 Joined: Fri Mar 18, 2011 6:47 pm
Post
by rimai » Tue Sep 29, 2015 5:49 pm
Yes, you can do that.
Do you use android app?
You can use StandardLights and MHLights.
They use 2 different schedules, but the memory locations for MHLights are only available on the android app or you would have to use direct HTTP calls to the controller.
Spotted
Post
by Spotted » Tue Sep 29, 2015 6:15 pm
I do use the android app and I think I would be lost without it!! I totally love it!
Spotted
Post
by Spotted » Tue Sep 29, 2015 6:21 pm
I understand that if I put the times in the code, I can't change it without recoding. If I put the times in the internal memory then I can change them from the app, is this correct?
I only need to occasionally change one set of times maybe from time to time.
Also I can set delay ports in the code too, like I would with lighting times? I have 2 different delay times one for the return pump to come on 2 minutes and another for the skimmer to come on after 5 minutes.
How would I define which port is used for the MHLights and which for the StandardLights if I wanted to go all internal memory?
Sorry, I have no coding skills, I am a home theater installer. Ask me to hang your TV or put speakers in your ceiling, I'm all over that!!
Post
by rimai » Tue Sep 29, 2015 6:48 pm
You can use:
ReefAngel.StandardLights(Port1);
ReefAngel.MHLights(Port2);
The delay timer is only one though.
Spotted
Post
by Spotted » Thu Oct 08, 2015 3:22 pm
Ok, so I have set up internal memory stuff.. I'm having a little trouble with an aqualifter that I want to come on every hour for 15 minutes. Right now it seems to stay on all the time.
Here is the code I'm using for it. Can you let me know if this is correct?
if (now()%3600<900)
{ //Every 60 minutes
ReefAngel.Relay.On(Box1_Port3); // Turn on Aqualifter for 15 minutes
I was also wondering if I could get the aqualifter to kick on for a few minutes after feeding mode ends. The lifter is used to clear air out of an overflow.
Here's my whole code just in case
ReefAngel.LightsOnPortsE[0] = Port1Bit;
ReefAngel.Relay.On( Port3 ); //Sump Powerhead. Relay 1 Port 3
ReefAngel.Relay.On( Port5 ); //Display Tank Power Heads Relay 1 Port 5
ReefAngel.Relay.On( Port8 ); //Return Pump Relay 1 Port 8
ReefAngel.Relay.On( Box1_Port1 ); //ATS Air Pump. Relay 2 Port 1
ReefAngel.Relay.On( Box1_Port2 ); //Media Reactor. Relay 2 Port 2
ReefAngel.Relay.On( Box1_Port8 ); //Reef Breeders LED Light. Relay 2 Port 8
ReefAngel.StandardHeater( Port6 ); //Relay 1 Port 6
ReefAngel.Relay.DelayedOn( Port7 ); //Skimmer Relay 1 Port 7
ReefAngel.MHLights( Box1_Port4 ); //ATS Light Relay 2 Port 4
if (now()%3600<900)
if (hour()>=22 || hour()<9)
{ // Sleep mode - slow things down
ReefAngel.DCPump.SetMode( ReefCrest,25,10 );
// Normal power
ReefAngel.DCPump.SetMode( ReefCrest,50,10 );
ReefAngel.DDNS( "7730.homeip.net:2000" ); // Your DDNS is spotted-7730.homeip.net:2000.myreefangel.com
Posts: 5422 Joined: Fri Jul 20, 2012 9:42 am
Post
by lnevo » Thu Oct 08, 2015 5:01 pm
Add an off statement before or an else statement as part of the if.
Post
by lnevo » Thu Oct 08, 2015 5:02 pm
Another way to do it is this
ReefAngel.Relay.Set(Box1_Port3, now()%3600<900);
Then you dont need any if statement because your setting the relay state on/off based on the result of your expression true/false.
Spotted
Post
by Spotted » Thu Oct 08, 2015 8:08 pm
So replace all of this
if (now()%3600<900)
with this?
Spotted
Post
by Spotted » Thu Oct 08, 2015 8:26 pm
The other way with the else statement would look like this?
if (now()%3600<900)
} else {
ReefAngel.Relay.Off(Box1_Port3);
I'm trying to learn how to properly use the if/else statement.
Post
by lnevo » Thu Oct 08, 2015 8:58 pm
Like this:
if (now()%3600<900)
} else {
you had an extra }
Spotted
Post
by Spotted » Fri Oct 09, 2015 5:38 am
Yes
I see it, the line above the else line right?
So how about this? This looks a lot less complicated than the if else argument,.
Spotted wrote: So replace all of this
if (now()%3600<900)
with this?
Post
by lnevo » Fri Oct 09, 2015 10:16 am
Yes and yes
Spotted
Post
by Spotted » Sat Oct 10, 2015 4:33 am
I'm happy, my code is coming along.
Next project. Is there a way to get the power heads to go into Nutrient Transport mode after a feeding?
Can I modify this to work?
Just change the times to coincide with the automated feeding?
Post
by lnevo » Sat Oct 10, 2015 8:54 am
If you're good at reading code you should try and look through my INO. I know mine is a bit complex so I'll try and simplify the request here for you:
int ntmDelay=300; // Time to wait before starting Nutrient Transport
int ntmTime=7200; // Time to run Nutrient Transport
static time_t t;
if (now()-t > ntmDelay && now()-t < ntmTime+ntmDelay) {
ReefAngel.DCPump.Mode=NutrientTransport;
if (ReefAngel.DisplayedMenu==FEEDING_MODE) {
t=now(); // Run post feeding mode when this counter stops
Spotted
Post
by Spotted » Sun Oct 11, 2015 6:21 pm
Ok, I don't think I'm going to use the NT mode after feeding. I might schedule it at a certain time of the day instead.
I have another request. I have the 12V power thingy I want to use to run a couple of water solenoid valves. I understand that it shows up as another relay box. I understand that I need to write it in the code as follows to turn ports on and off.
ReefAngel.Relay.On(Box2_Port3);
Thing is I will only be using them right now as manual ports to refill my ATO reservoir and water change barrels. How do I make them accessible in the app?
Post
by lnevo » Sun Oct 11, 2015 9:10 pm
They should show up once activated. If you don't already have a relay expansion, it should be Box1 rather than Box2.
Spotted
Post
by Spotted » Mon Oct 12, 2015 3:18 am
I do have another relay. I have 2 regular relay boxes and then the 12 volt power expansion. How would I activate it? Just plug it in to the system and it adds another set of relays in the app?
Post
by lnevo » Mon Oct 12, 2015 5:09 am
Reference it in the code, then compile and upload and it should be recognized.
Spotted
Post
by Spotted » Mon Oct 12, 2015 9:23 am
I'm sorry, I am not sure how to reference it in the code. I'm not a coder. I'm a home theater installer.. Sorry...
Spotted
Post
by Spotted » Mon Oct 12, 2015 9:34 am
Actually I think I understand. I could just reference them as off in the code and then I will get the ability to control them in the app right? Something like this?
ReefAngel.Relay.Off(Box3_Port1);
ReefAngel.Relay.Off(Box3_Port2);
Is this right?
Spotted
Post
by Spotted » Mon Oct 12, 2015 10:39 am
No, It should be
ReefAngel.Relay.Off(Box2_Port1);
ReefAngel.Relay.Off(Box2_Port2);
Box2 not Box3, yes?
I got a Main Relay (Box), Expansion Relay(Box1), and the Power Control Module(Box2)
Yes?
Post
by lnevo » Mon Oct 12, 2015 11:41 am
Yes
