Reef Angel AWOL
- Rodasphoto
- Contact:
Reef Angel AWOL
My RA+ is turning my lights on at the wrong times and won't respond to commands via portal or the app on my phone. I tried reseting the time and making sure my connections are tight. What else can I check? I will probably reload my code when I get home.
- Rodasphoto
- Contact:
Re: Reef Angel AWAL
So I disconnected everything and tried my dimming module on its own connected directly and it worked. I also checked both relay boxes as well. So I know its not the dimming module or the relay boxes.. I noticed that the light on the expansion module does not light up. : (
Also of note is that the timing of events is off. I have my lights to turn off b/w 19:00 and 18:00 and they are still on.
I tried to upload my code again and it gets to about 90% then hangs indefinitely.
- Rodasphoto
- Contact:
Re: Reef Angel AWOL
So the cable to the expansion module was the issue. But still can't upload my code.
Sent from my Nexus 6 using Tapatalk
- Rodasphoto
- Contact:
Re: Reef Angel AWOL
rimai wrote:Can you upload any other code?
I will try tonight when I get home from work.
- Rodasphoto
- Contact:
Re: Reef Angel AWOL
So I tried uploading the preloaded code and get the same results. Also when I came home my lights were off, the light on the expansion module was off, the red light on the RA was blinking, and the screen was cycling between all menus.
Re: Reef Angel AWOL
Did you try loading with just the head unit ando USB power cable?
Blinking redo status means bus lock.
Disconnect any expansion module and see which one is causing the problem.
- Rodasphoto
- Contact:
Re: Reef Angel AWOL
I tired to upload it with it connected to both VGA and USB. I have never tried to do it any other way.
I know its not the dimming module as my lights dim and turn on/off normally.
What are causes of bus lock?
Re: Reef Angel AWOL
You can use the USB power cable if you have one.
You can use it to power the head unit without the relay box.
The bus lock is caused by something in the expansion bus.
You just stated the lights were not working in the previous post.
Please disconnect all modules and probes to see if the bus lock stops.
- Rodasphoto
- Contact:
Re: Reef Angel AWOL
So no bus lock. I tried to upload code to the controller with only connected to USB and it only gets to 90% and then hangs. Also one the channels on my dimming expansion quit working.
Re: Reef Angel AWOL
Does i0t hangs on 90% on any code?
Try this code:
Try this code:
- Rodasphoto
- Contact:
Re: Reef Angel AWOL
I get the following when trying to upload the code above:rimai wrote:Does i0t hangs on 90% on any code?
Try this code:Code: Select all
void setup() { } void loop() { }
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 466 bytes (of a 32,256 byte maximum)
avrdude: stk500_recv(): programmer is not responding
- Rodasphoto
- Contact:
- Rodasphoto
- Contact:
Re: Reef Angel AWOL
I ordered some new USB cables in hopes that this fix the issues I am having.
But I am curious as to why I can't it hangs when trying to upload code to the controller.
Re: Reef Angel AWOL
You've got the wrong board configured if this is an RA+. It's saying you only have 32k available which means it's looking for a standard board.
- Rodasphoto
- Contact:
Re: Reef Angel AWOL
I have been using Reef Angel Controller w/optiboot. Should I use Reef Angel Plus Controller? Sorry for the dumb question.lnevo wrote:You've got the wrong board configured if this is an RA+. It's saying you only have 32k available which means it's looking for a standard board.
Many thanks. I did not see you had posted when I asked using Tapatalk.
- Rodasphoto
- Contact:
- Rodasphoto
- Contact:
Re: Reef Angel AWOL
Just tried with the board set to Reef Angel Controller and serial port set to /dev/tty.usbserial-A901MIKW. I got the following error:
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Relay Expansion Module
Dimming Expansion Module
2014 Main Screen
Simple Menu
Binary sketch size: 60,704 bytes (of a 258,048 byte maximum)
- Rodasphoto
- Contact:
Re: Reef Angel AWOL
So I have tried running the controller with just the dimming expansion no bus lock. I tried running the controller with the expansion hub and dimming module- bus lock. Expansion hub and expansion hub- bus lock. This leads me to think that maybe my expansion hub is bad. I noticed the led on the expansion hub starts off bright and then goes dim to off as time passes. Maybe Rimai will let me exchange it for a working one. I also have yet been able to update my code. I am not sure what else to do/check. I have changed all of the USB cables.
- Rodasphoto
- Contact:
Re: Reef Angel AWOL
Expansion hub and expansion module. The one that allows for an set of relays to plug equipment into.lnevo wrote:Expansion hub and expansion hub?
- Rodasphoto
- Contact:
Re: Reef Angel AWOL
Just tried upload the code above and got the following errorrimai wrote:Does i0t hangs on 90% on any code?
avrdude: stk500v2_command(): unknown status 0x01
avrdude: stk500v2_disable(): failed to leave programming mode
