Ask in here.
tyson_mitchell_88
Posts: 80 Joined: Thu Nov 05, 2015 2:45 pm
Post
by tyson_mitchell_88 » Sat Jan 23, 2016 2:27 am
Hi,
I need to flick a port off and on again. Thought something like this but I'm not sure if I'm remotely right.
//White off
if (hour()==18 && minute()==30 && second()>=0 && hour()==18 && minute()==30 && second()<2)
ReefAngel.Relay.Off(Port8);
} else {
ReefAngel.Relay.On(Port8);
Or is it just
//White off
if (hour()==18 && minute()==30 && second()==0)
} else {
Posts: 1437 Joined: Fri Mar 29, 2013 3:51 pm
Post
by cosmith71 » Sat Jan 23, 2016 4:53 am
Either of those should work. I'd go with the first one just because it has a little more delay.
Be aware that except for those two seconds, that port will ALWAYS be on with that code. You would also need to place it after any other code that controls that port.
tyson_mitchell_88
Post
by tyson_mitchell_88 » Sat Jan 23, 2016 5:32 am
So if I go with this it should just turn off for those 2 sec. Otherwise will be on 500 > 2100.
Thanks Colin
//White off
} else {
ReefAngel.StandardLights( Port8,5,00,21,00 );
Post
by cosmith71 » Sat Jan 23, 2016 5:41 am
There are a couple of ways.
You can do it the way you have posted.
You can do this, too.
//White off
if (hour()==18 && minute()==30 && second()<2)
} else {
You could also have the StandardLights up higher in your loop() and leave out the else completely.
loop()
ReefAngel.Standardlights( Port8,5,0,21,0);
tyson_mitchell_88
Post
by tyson_mitchell_88 » Sat Jan 23, 2016 5:52 am
Yep changing it to the second way. Should of thought of it from the start lol. Thanks mate
