There was a slight hiccough with the SoftwareSerial library that was not allowing the code to compile at first, but updating SoftwareSerial.cpp solved that problem. I saw another suggestion to update or change the RA_Joystick.h, but I haven't been able to find that library in the RA Program Files.
Any other suggestions or solutions? We are trying to set-up our ATO system.
Also, where is the RA_Joystick library located in the Program Files so that I can update it?
Reinstalling the Arduino software did not update the libraries, it only set us backwards so I have to go back and at least update the SoftwareSerial library.
#include <SoftwareSerial.h>
// Define Relay Ports by Name
#define DT_Pump 1
#define Heater 2
#define UV 3
#define Swabbie 4
#define Ozone_Pump 5
#define Skimmer 6
#define Fan 7
#define Frag_Tank 8
#define Kalkwasser Box1_Port1
#define Desk_Can_Lights Box1_Port2
#define DT_White Box1_Port3
#define DT_Blue Box1_Port4
#define Powerheads Box1_Port5
#define Refuge_Light Box1_Port6
#define Moonlights Box1_Port7
#define ATO_Pump Box1_Port8
// Does not need to be global.
// unsigned long ATOUpdate=0;
static time_t LastATO=millis(); // For de-bounced ATO
ReefAngel.AddORPExpansion(); // ORP Expansion Module
ReefAngel.AddPHExpansion(); // pH Expansion Module
ReefAngel.AddMultiChannelWaterLevelExpansion(); // Multi-Channel Water Level Expanion Module
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
ReefAngel.FeedingModePortsE[0] = Port8Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePortsE[0] = Port8Bit;
ReefAngel.LightsOnPorts = Port8Bit;
ReefAngel.LightsOnPortsE[0] = Port3Bit | Port4Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPortsE[0] = Port3Bit | Port4Bit | Port6Bit | Port7Bit;
InternalMemory.OverheatTemp_write( 835 );
//Set Standard Menu
ReefAngel.AddStandardMenu();
//Webserver Authentication
ReefAngel.Network.WifiAuthentication("hnnhflns");
//DDNS Server
ReefAngel.DDNS("300");
ReefAngel.StandardHeater( Port2,765,768 );
ReefAngel.Relay.DelayedOn( Port3,10 );
ReefAngel.DosingPumpRepeat( Port4,0,480,60 );
ReefAngel.StandardLights( Port5,9,0,14,0 );
ReefAngel.Relay.DelayedOn( Port6,10 );
ReefAngel.StandardFan( Port7,808,810 );
ReefAngel.StandardLights( Port8,0,0,8,0 );
ReefAngel.StandardLights( Box1_Port3,14,0,22,0 );
ReefAngel.StandardLights( Box1_Port4,11,0,23,59 );
ReefAngel.StandardLights( Box1_Port6,23,0,0,0 );
ReefAngel.StandardLights( Box1_Port7,23,0,1,0 );
// ******************* Debounced ATO code. Activate ATO no more than every 30 seconds. *******************
//if (ReefAngel.WaterLevel.GetLevel(0) < 34) LastATO=millis(); // Start a timer
//if (millis()-LastATO<30000 && millis()-LastATO>10) // Has it been less than 30,000 ms? (30 secs)
// ReefAngel.Relay.Off(ATO_Pump); // If so, make sure the topoff pump is off
// else
ReefAngel.WaterLevelATO( Box1_Port8,ATO_Pump,600,75,90 ); // Otherwise, use the normal topoff routine.
ReefAngel.DCPump.SetMode( Constant,50,10 );
//Mix Kalkwasser
static unsigned long Kalk_Mixing = 0;
static unsigned long stopTime = 0;
static byte prevWL=0;
if (ReefAngel.WaterLevel.GetLevel(1)==100 && prevWL<100) {
stopTime=now()+7200; // Get time one hour from now.
prevWL = ReefAngel.WaterLevel.GetLevel(1); // Store the water level
if (now() < stopTime) { ReefAngel.Relay.On(Kalkwasser); } else { ReefAngel.Relay.Off(Kalkwasser); }
// Delay WL ATO after water change
static time_t wcTimer=0;
if (ReefAngel.DisplayedMenu == WATERCHANGE_MODE) wcTimer=now();
// First 10 minutes after WC disable ATO
if (now()-wcTimer >= 0 && now()-wcTimer < 600)
ReefAngel.WaterLevelATO(0,ATO_Pump,720,0,1);
// Disable ATO if ATO High IsActive()
//Beginning of Jebao Control through Actinic and Daylight ports.
if (hour()<1 || hour()>=8)
ReefAngel.PWM.SetActinic(20);
ReefAngel.PWM.SetDaylight(20);
else if (hour()>=8 && hour()<15)
ReefAngel.PWM.SetDaylight( TidalSwellMode(30,true) ); // Tidal Swell at 40% on sync mode
ReefAngel.PWM.SetActinic( TidalSwellMode(30,false) ); // Tidal Swell at 40% on anti-sync mode
else if (hour()>=15 && hour()<17)
ReefAngel.PWM.SetDaylight( ReefCrestMode(100,85,true) ); // ReefCrest at 100% + - 85 on sync mode
ReefAngel.PWM.SetActinic( ReefCrestMode(100,85,false) ); // ReefCrest at 100% + - 85 on anti-sync mode
else if (hour()>=17 && hour()<19)
ReefAngel.PWM.SetDaylight( NutrientTransportMode(90,100,2000,true) ); // Nutrient Transport on sync mode
ReefAngel.PWM.SetActinic( NutrientTransportMode(90,100,2000,false) ); // Nutrient Transport on anti-sync mode
else if (hour()>=19 && hour()<21)
else if (hour()>=21 && hour()<22)
ReefAngel.PWM.SetDaylight( ElseMode(100,85,true )); // ElseMode on sync mode, 100 +/- 85%
ReefAngel.PWM.SetActinic( ElseMode(100,85,false )); // ElseMode on sync mode, 100 +/- 85%
else if (hour()>=22 && hour()<23)
ReefAngel.PWM.SetDaylight( TidalSwellMode(80,true) ); // Tidal Swell at 40% on sync mode
ReefAngel.PWM.SetActinic( TidalSwellMode(80,false) ); // Tidal Swell at 40% on anti-sync mode
else if (hour()>=23 && hour()<1)
ReefAngel.PWM.SetDaylight( LongPulseMode(0,20,10,true) ); // Long pulse at 20% with 10s pulse on sync mode
ReefAngel.PWM.SetActinic( LongPulseMode(0,20,10,false) ); // Long pulse at 20% with 10s pulse on anti sync mode
//End of Jebao Control
ReefAngel.Portal( "hnnhflns" );
ReefAngel.DDNS( "300" ); // Your DDNS is hnnhflns-300.myreefangel.com
int x,y;
// pH Expansion
ReefAngel.LCD.DrawText( COLOR_MEDIUMSEAGREEN,DefaultBGColor,15,66, "PHE:" );
ReefAngel.LCD.DrawSingleMonitor( ReefAngel.Params.PHExp,COLOR_MEDIUMSEAGREEN,39,66, 100 );
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,57, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,57, ReefAngel.WaterLevel.GetLevel() );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,66,66, "WL 1:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel(1) );
ReefAngel.LCD.DrawOutletBox(12, 104, TempRelay);
