Best way to build my coding?
ingtar_shinowa
Post by ingtar_shinowa »
I want to have some very basic function as well as some greater functions. For now im looking to build a refugium schedule, basic ATO heaters pump skimmer, reactors, and wavemaker:
       randomSeed(analogRead(0));
        ReefAngel.Timer[1].SetInterval(random(15,35));
        ReefAngel.Timer[1].Start();
        ReefAngel.Relay.On(Port5);
Should I build my PDE piece-mail then put it all together with custom port names?
Also how would i put in a menu item for changing media for my reactors?
Sorry for the beginner post but im not a big programming guy.
Re: Best way to build my coding?
I think you should start with RAGen:
http://forum.reefangel.com/viewtopic.php?f=15&t=60
ingtar_shinowa
So last night RAGen was working fine, but today when I click on it it wont open.
Seedlessone
Post by Seedlessone »
I had the same problem with RAGEN. Try this....
It's because the paths are wrong.
Try this then:
1. Download the static version:
https://github.com/downloads/curtbinder ... static.zip
2. Try running is as administrator
3. Make sure to go to menu Edit->Settings
4. Set the path of the folders to the following:
Sketch: Documents\Arduino
Libraries: Documents\Arduino\libraries
Arduino: C:\Program Files\Reef Angel Controller
5. Click Ok.
6. You can now delete the static version if you want to.
I hope this works now.
ingtar_shinowa
Figured it out. My anti virus was interfearing.
The code I made is ato on 1, return pump on 2, skimmer on 3, powerheads 4&5, reactors on 6, heaters on 7, and fuge lights on 8.
For H2O/reactor change with simple menu I turn off ATo, skimmer, return, and reactor pump.
Feed mode just turns off my main powerheads.
// Autogenerated file by RAGen (v1.1.0.126), (01/29/2012 15:35)
// RA_012912_1535.pde
#define DisplayImages
#define DateTimeSetup
#define VersionMenu
#define DirectTempSensor
#define SaveRelayState
#define SIMPLE_MENU
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
    ReefAngel.FeedingModePorts = B00011000;
    ReefAngel.WaterChangePorts = B00100111;
    ReefAngel.OverheatShutoffPorts = B00000000;
    ReefAngel.LightsOnPorts = B00000000;
    ReefAngel.Relay.On(Port2);
    // Specific functions
    ReefAngel.StandardATO(Port1);
    ReefAngel.Relay.DelayedOn(Port3, 5);
    ReefAngel.Wavemaker1(Port4);
    ReefAngel.Wavemaker2(Port5);
    ReefAngel.Relay.DelayedOn(Port6, 5);
    ReefAngel.StandardLights(Port8);
ingtar_shinowa
Now in order to insert the wavemaker code into this set up do I need to mess with the memory setting? I just put in the standard setting which I need to change to work reverse lighting on the fuge light since with the RAGen code it works off memory?
ingtar_shinowa
Or should I build my code with 4 and 5 not used, then add in the code above?
The wavemaker code is already in there:
But I would strongly recommend you putting the wavemakers on ports 5 and 6 by generating it again with RAGen.
ingtar_shinowa
Oh ok i thought 4-5 were the fast toggle relays
ingtar_shinowa
One of the reason I want to alter the settings is for the random flow between 15-35 seconds.
ingtar_shinowa
OK here it is swapped around
1 ATO
2 Return
3 Skimmer
4 Reactors
5 left flow
6 right flow
7 heaters
8 fuge light
// Autogenerated file by RAGen (v1.1.0.126), (01/29/2012 17:07)
// RA_012912_1707.pde
#define VersionMenu
#define SIMPLE_MENU
    ReefAngel.FeedingModePorts = B00110000;
    ReefAngel.WaterChangePorts = B00001111;
    ReefAngel.OverheatShutoffPorts = B01000000;
    ReefAngel.Relay.DelayedOn(Port4, 5);
    ReefAngel.Wavemaker1(Port5);
    ReefAngel.Wavemaker2(Port6);
Ok, if you want the random action, I updated your code for your reference:
 #define VersionMenu
 #define SIMPLE_MENU
ingtar_shinowa
Roberto you are my favorite!!! I've been following this idea of yours since the beginning but I took the plunge because of the great support you and others put into this community! Thanks again for the help!!!!!
Glad to help :)
ingtar_shinowa
hmmm say m y sketch is too big
Seedlessone
Might try leaving out the data time feature in ragen. Seems it takes up quite a bit of space.
ingtar_shinowa
Binary sketch size: 31196 bytes (of a 30720 byte maximum)
doesnt matter how many feature i pull out it say the same thing.
ingtar_shinowa
I fin this a little frustrating seeing how much other people are doing with their units. I have to be doing something wrong.
Use the simple menu feature.
It'll reduce quite a lot, actually.
ingtar_shinowa
I am in that arent i?
ingtar_shinowa
DO I need to wipe my memory file and reload it with less 'stuff' in it, the things i dont need (MH lighting, dosing, etc), in order to lower my sketch size?
No, the memory file just sets the values to the Internal Memory for use with the sketch / program files later on.
The more things you enable in the Features file (Features Tab in the program), the larger the sketch size will be.
Date & Time Setup requires a lot of space, so it's advised to not include it.
Simple Menu reduces a lot of space, so it's advised to use it.
If you are using the Client Suite or any of the monitoring applications (Android, iPhone/iPad apps or Status App), you must have wifi enabled for communications with the controller. Wifi does require a lot of space.
Bottom line, the more stuff you have the controller do, the larger the sketch size will be.
Make sure the paths are set correctly too, like the earlier post:
http://forum.reefangel.com/viewtopic.php?p=5291#p5291
ingtar_shinowa
SO WIERD! I don't understand why now when I complie it 24274 bytes but last night compling the same code is was 31k
ingtar_shinowa
Its ALIVE! Thanks everyone for you help. I did run RAGen static and the seemed to fix all my issues. The other download seemed to wrok for a few start ups than never again lol. /shrug
