Here's some screenshots from my uapp
Background:
Started getting low temp emails from RA stating that the temp was zero. Every time I checked my app everything appeared to be fine. This started about 30 days ago.
Now it's been reading zero for at least a half hour, but the relay is still acting as though it's getting a reading. The heater isn't coming on etx.
I have a spare probe that i plugged in - nothing
Re-booted the controller - nothing.
It's making me very nervous. Any ideas???
Weird temp probe issues
Re: Weird temp probe issues
And now, looking around at my relay activity, it seems my dosing pump hasn't been coming on. What's going on here? This code and controller hasn't been touched since early 2015. I'm pretty disappointed.
Ok...I'm a genius. Fixed the probe but what about the relay not turning on when it's supposed to?
You won't see dosing pump activity on the relay chart.
The controller only sends data every 5 minutes.
Unless your pump stays on for that long, chances of seeing it on the relay activity are slim.
Thanks for clearing that up! I was getting freaked there for a bit.rimai wrote:You won't see dosing pump activity on the relay chart.
What portal is that?skehole wrote:Here's some screenshots from my uapp
Background:
saf1 wrote:What portal is that?skehole wrote:Here's some screenshots from my uapp
Background:
This is the iPhone U-App
