wifi help
Re: wifi help
The ssid and password is case sensitive.
Make sure it is the same case.
Also, try changing the password to not have a question mark. I'm not sure if that is causing any issue.
kga943
Re: wifi help
so all the things that say false should say true ?
kga943
Re: wifi help
That means you are all set.
You are reaching to the internal web server and you are ready to start using any of the phone apps
kga943
Re: wifi help
but when i try and connect with my phone it just says connecting but it never does
