Litany of strange goings on...
I have a variety of things currently happening and would love some assistance.
Switched router and modem and suddenly I could only access app from OUTSIDE my home wifi network.
To make things stranger I finally broke down and updated my wifi module and I can collect graph data and get them displayed in my home network and outside lte network, but cannot manipulate relays, or refresh my ph and temp while on my home network.
I recently switched from in code locations to internal memory on my ra+. All my relays are behaving as programmed according to my app, but my temperature changes (from 77.5-8, to 77-77.5)are not taking place according to my relay and graph data.
Let me know if there's anything further that is needed to figure out what's going on. I am not a tech savvy person. I am a tile contractor and work with my hands. I am starting to wonder if this platform was not the right choice for my skill set lol.
Re: Litany of strange goings on...
Can you copy and post your code so we can make sure it's ok? Can you access the portal on the web? Are you trying to use the App from your phone/table?
Did you also change internet provider.
I have comcast and cannot access my outside ip when I'm in my own wifi network.
They use a router that doesn't allow loopback.
I created two profiles on Android app.
One for when I'm home and one for when I'm outside.
I did not change providers no.rimai wrote:Did you also change internet provider.
Also, I went in to internal memory via the app, changed the temp parameters, then changed them back to where I wanted them and they seemed to recognize the new numbers for some reason.
I will post my code once my kids are asleep lol. Although it is EXTREMELY rudimentary and was solely generated through the wizard
Will post the code as mentioned previously but no, the portal will not allow me to change my relays.GugsJr wrote:Can you copy and post your code so we can make sure it's ok? Can you access the portal on the web? Are you trying to use the App from your phone/table?
Taken literally seconds apart
here's the code
ReefAngel.WaterChangePorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit;
ReefAngel.Relay.On( Port2 );
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1 );
ReefAngel.Portal( "skehole" );
ReefAngel.DDNS( "fish tank" ); // Your DDNS is skehole-fish tank.myreefangel.com
And never mind on the controllers int memory working on the heater.
That's good to see.
What is? Lol....am I missing something?GugsJr wrote:That's good to see.
Looks like your temps are working. They are going to fluctuate a bit because it takes time for them to go on and go off. You can set the range a bit lower then 77 if you want it to get to 77
Why are my relays on the portal not reflecting the relays on the app?
The labels? Or you mean you can't access the relays from the portal.
If it's the labels you have to change the names in the portal and download them to the app.
If you can't access the relays from the portals. Probably means your port forwarding isn't set up correctly.
GugsJr wrote:The labels? Or you mean you can't access the relays from the portal.
if you compare the two pictures I posted of my app screen shot and the portal photo, the auto, on , and off do not correlate from one to the other.
And honestly, I don't care too much as I use the U-App exclusively but just wanting things to work either way just in case
Oh I see that, honestly I'm not sure. Roberto probably would be the person you need help from.
It says the last time you sent data to the portal was 3/23/2017, 12:33:07 PM
That's strange seeing as how I posted the screenshot on the 24th. What would cause that to happen? Port forwarding is working on my U-Apprimai wrote:It says the last time you sent data to the portal was 3/23/2017, 12:33:07 PM
Yes I switched to internal memory coding. The code should be listed above. Also noticing that my graphs will not allow me to go beyond 1 or 12 hour time periodsrimai wrote:Did you change code around that time?
It is because your last data was 03/23 and it only keeps for 7 days.
Tomorrow you won't have data.
I think it is because of the space on the ddns.
Try removing that space.
Can you show me where you're talking about? I assume it's at the end, but I'm not sure what space you're talking about.rimai wrote:I think it is because of the space on the ddns.
Also, this was generated via the wizard and was not altered in any way.
Yes, the space on your ddns line.
Use fishtank without a space.
HTTP protocol doesn't understand spaces.
Gotcha. Thanks I will try when I get back in town.rimai wrote:Yes, the space on your ddns line.Use fishtank without a space.Code: Select all
That appears to have done it. Thanks!
