Light Timer - ON_OFF then Back ON
lh2o
Hi
Greetings ,
I woul like to have port 2 (bellowin red ) (go ON at 7 :00 then OFF at 7:01and then back ON until 19:00 when it goes OFF
it sounds weird but it's to corect a strange issues I have with my Euroaquatic LED T5... they do not start up when the ports goes ON but if I put it OFF the back ON again they start up fine
below is what I have generated from teh Wizard
thanks
ReefAngel.Relay.DelayedOn( Port3,5 );
ReefAngel.StandardLights( Port4,16,0,10,0 );
ReefAngel.StandardHeater( Port5,775,786 );
ReefAngel.StandardHeater( Port6,775,786 );
ReefAngel.StandardLights( Box1_Port1,8,0,18,0 );
ReefAngel.StandardLights( Box1_Port2,7,0,19,0 );
ReefAngel.StandardLights( Box1_Port3,10,30,15,30 );
ReefAngel.StandardLights( Box1_Port4,10,30,15,30 );
Greetings ,
thanks
Re: Light Timer - ON_OFF then Back ON
Try this:
if (hour()==7 && minute()==1) ReefAngel.Relay.Off(Box1_Port2);
lh2o
thnk you , where shoupl I paste this ?
In the custom section.
Below the last line posted above.
lh2o
thanks Roberto , It's doing what I wanted wich is great but not solving the issue I have with the T5 bulbs not lighting
when I use the UAPP and manualy togle the port to OFF then Auto the T5 go on ...woudl there be another way to try coding this
thanks
thanks
I didn't get it what you are saying about the Uapp.
Can you rephrase please?
lh2o
when this port is set ON by the timer (at 7:00) the light flicker but do not stay ON, witwhat you suegested I paste they fliker again about 1 min later but do not stay on.
If I use the Universal App on my I phone and set the port to Off the Auto the lights start up.
thsi is not an issue with this relay or the controler... the issue is linked to the E5 led tT5 because when I put regular T5 I have no problems
what I am looking for in terms of code is somthing that would mimic what I am doing in the U app
hope thsi makes sens
thanks
thanks
So, what do you need?
A shorter off interval?
Right now it stays for a whole minute.
Maybe you just need a few seconds?
lh2o
yes I think that could work ! just a couple second Off like 1 or 2 would be great
thank you
thank you
Just add seconds then.
if (hour()==7 && minute()==1 && second() <=2) ReefAngel.Relay.Off(Box1_Port2);
lh2o
thanks a lot !!! it works perfect
am I glad I went with a Reff Angel
!!! your support is awsome
all teh best
all teh best
